Cloud services fail after modem change
gatorback
An Arris modem replaced the Xfinity modem. The Mac on the Wifi returns web pages (i.e. internet is working). The Mac is also able to ping the Honeywell thermostat:
ping -c 3 192.168.8.121
I noticed two services that seem to fail:
* Thermostat display normally reports outside temperature, but now indicates "internet connection lost"
* Asus DDNS connection does not update mydomain.asuscomm.com More details published here:
Given that these two similar problems surfaced after changing out the modem. What "root cause" is plausible, so that I can take corrective measures?
Check your IP settings on the new modem to make sure they match the old, same with SSID & Passphrase. Your gateway was changed which means everything associated with the old equipment has now changed. It is not a simple plug and play.
