The Desolate One
Hello all. I’m the on site computer tech at a small school. The principal has approved a small budget to provide wireless access throughout the entire school. The maximum amount of money I can spend [per] router is $40.00 and the maximum amount of routers I can buy is six. They will be strategically placed throughout the school for maximum coverage. I need the best wireless router I can get for 40 bux that does well with sending signals through thick walls. I realize that this is a stretch, considering the amount I’ll be spending for each router, that’s why I’m asking you all what the best bang for the school’s buck would be. If any of you have experience with using a router that costs 40 bux or less, and that does a good (or at least decent) job punching it’s signal though thick wall areas, your advice would be greatly appreciated…..
