Skynet Curl "no URL specified" error when changing Skynet blacklist
MWGlidden
Attempting what seems like a simple Skynet change to me, switching to firehol_level1. It generates a curl error that I'm unable to solve so far. I assumed it was OK to use FireHOL's URL as the input and that could be my mistake. What's the right approach here?
Input Custom Filter List URL:
[URL]: https://raw.githubusercontent.com/ktsaou/blocklist-ipsets/master/firehol_level1.netset
[$] /jffs/scripts/firewall banmalware https://raw.githubusercontent.com/ktsaou/blocklist-ipsets/master/firehol_level1.netset
[i] Custom Filter Detected: https://raw.githubusercontent.com/ktsaou/blocklist-ipsets/master/firehol_level1.netset
[i] Downloading filter.list         | [0s]
[i] Refreshing Whitelists           | [8s]
[i] Consolidating Blacklist         | curl: no URL specified!
curl: try 'curl --help' for more information [0s]
[*] List Content Error Detected - Stopping Banmalware
You need to input a filter list url, not a blacklist. Look at the example default filter list for example (a filter list is made up of multiple blacklist URL’s)
I am having a similar experience.
I just found that Skynet was not running and it seems like the USB was going bad. So I backed up the files from my old USB and formatted a new USB, installed amtm, entware, Skynet, etc.
I did not restore any files *yet* because I am not sure what I can/should restore. Anytime I run a Skynet command, I get lots of curl errors like "curl: option --retry-all-errors: is unknown". Its been so long since I originally installed all of this, I cannot remember much about it.
Now that I have a new USB and I installed Skynet, can I bring in my old settings and/or what do I need to do to get it to work?
A Use the VPN base on URL rather than IP address Asuswrt-Merlin AddOns 3
