Default clkfreq nvram on RT-AX86U?
mr8
Hello,
I was transferring some /jffs/scripts from another router and one of the files had an overclock line "nvram set clkfreq=1200,800" that I missed.
I tried to unset the value and did a factory reset but "nvram get clikfreq" value is still empty.
Is there anything else I need to do?
That's a typo.
Are you sure it's empty? Using a nonexistent variable name won't report an error.
admin@RT-AC68U:/# nvram get dsfkflkfaslkfjhaslfhja
admin@RT-AC68U:/#
An empty string would look like this:
admin@RT-AC68U:/# nvram get wan1_vendorid
admin@RT-AC68U:/#
That's a typo.
admin@RT-AC68U:/#
admin@RT-AC68U:/#
whoops, looks like that was an auto correct on my keyboard.
ssh command is still blank with *clkfreq*:
admin@RT-AX86U-8660:/# nvram get clkfreq
admin@RT-AX86U-8660:/# nvram show | grep clk
size: 76329 bytes (54743 left)
It looks like that variable simply doesn't exist anymore on the AX routers. I wouldn't worry about it as it can't be changed anyway.
