[DIY] - SmallNetworks - Learning by Doing
Storage Part Three
===== Logical Volume Management =====
Before we go to far - if your needs are very simple, and you have enough space on your primary drive, then skip down to the SAMBA section, otherwise read on.
**WARNING - everything in this section has the ability to completely and utterly destroy data - what you do with your data is your business - these steps, if not clearly understood, will result in unrecoverable data loss to the drives/devices/volumes being worked on - back up your drives before considering any of these steps**
The Linux Logical Volume Manager (LVM) is a mechanism for virtualizing disks. It can create "virtual" disk partitions out of one or more physical hard drives, allowing you to grow, shrink, or move those partitions from drive to drive as your needs change. It also allows you to create larger partitions than you could achieve with a single drive.
Traditional uses of LVM have included databases and company file servers, but even home users may want large partitions for music or video collections, or for storing online backups. LVM and RAID 1 can also be convenient ways to gain redundancy without sacrificing flexibility.
This article looks first at a basic file server, then explains some variations on that theme, including adding redundancy with RAID 1 and some things to consider when using LVM for desktop machines.
Storage Part Four
==== LVM Basics ====
To use LVM, you must understand several elements.
First are the regular physical hard drives attached to the computer. The disk space on these devices is chopped up into partitions. Finally, a filesystem is written directly to a partition.
By comparison, in LVM, Volume Groups (VGs) are split up into logical volumes (LVs), where the filesystems ultimately reside
Each VG is made up of a pool of Physical Volumes (PVs). You can extend (or reduce) the size of a Volume Group by adding or removing as many PVs as you wish, provided there are enough PVs remaining to store the contents of all the allocated LVs. As long as there is available space in the VG, you can also grow and shrink the size of your LVs at will (although most filesystems don't like to shrink).
 **An Example LVM Stack**
//In the exercise below, we'll follow this design - it's here for teaching purposes only - in production this will work, but perhaps consider using xfs vs. ext4 for production, reasons there are in the advanced section//
^ Section              ^ Tool   ^ Data                        ^^
| Mounts               | mount  | /var/share      | /var/media |
| FileSystem           | mkfs   |ext4             | xfs   |
| Logical Volume       | lv     | /share          |/media      |
| Volume Group         | vg     | /dev/fileserver             ||
| RAID (if applicable) | mdadm  | /dev/md0                    ||
| Partitions           | pv     | /dev/sdb1       | /dev/sdc1  |
| Disks                | fdisk  | /dev/sdb        | /dev/sdc   |
Storage Part Five
==== Disk Hardware ====
Traditionally, a file server uses SCSI disks, but today SATA disks offer an attractive combination of speed and low cost. With USB3, it's even more so with external disks that are easy to attach (and easy to remove, which is not recommended if extending an LVM set to USB3)
SATA drives are not named like ATA drives (hda, hdb), but like SCSI (sda, sdb). Once the system has booted with SATA support, it has three physical devices mounted - the boot disk, which is generally, but may not be /dev/sda, and the two attached disks which are not part of the boot partition or file system.
For purposes of this discussion - the attached non-boot disks are;
  /dev/sdb  32.0 GB
  /dev/sdc  32.0 GB
Next, partition these for use with LVM. You can do this with fdisk by specifying the "Linux LVM" partition type 8e.
  fdisk /dev/sdb
<code>
Command (m for help); <-- d to delete existing partition
Command (m for help): <-- n for new partition
Command action
   e   extended
   p   primary partition (1-4) <-- p for primary
Partition number (1-4): <-- 1
First cylinder (1-10443, default 1): <-- <ENTER> to accept defaults
Using default value 1
Last cylinder or +size or +sizeM or +sizeK (1-10443, default 10443): <-- <ENTER> to accept defaults
Command (m for help): <-- t for type
Selected partition 1
Hex code (type L to list codes): <-- 8e
Changed system type of partition 1 to 8e (Linux LVM)
Command (m for help): <-- w to write the partion back to disk
The partition table has been altered!
Calling ioctl() to re-read partition table.
Syncing disks.
</code>
Now we do the same for the other hard disk /dev/sdc:
The finished product looks like this for my test drives:
<code>
sudo fdisk -l /dev/sdc
Disk /dev/sdc: 29.8 GiB, 32008830976 bytes, 62517248 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x5c6842c1
Device     Boot Start      End  Sectors  Size Id Type
/dev/sdc1        2048 62517247 62515200 29.8G fd 8e  Linux LVM
</code>
Note that the partition type here is '8e', or "Linux LVM."
Storage Part Six
==== Creating a Virtual Volume ====
We have 2 drives with Linux LVM Partition - sdb1 and sdc1
**Create the LVM PV Group**
Initialize each of the disks using the **pvcreate** command:
  pvcreate /dev/sdb1 /dev/sdc1
This sets up all the partitions on these drives for use under LVM, allowing creation of volume groups. To examine available PVs, use the **pvdisplay** command.
**Create the LVM Volume Group**
This system will use a single-volume group named fileserver:
  vgcreate fileserver /dev/sdb1 /dev/sdc1
Use **vgdisplay** to see the newly created "fileserver" VG with the two drives stitched together.
**Create the LVM Logical Volumes**
Now create the logical volumes within them:
  lvcreate --name media --size 20G fileserver
  lvcreate --name share --size 20G fileserver
Use **lvdisplay** to see the newly created logical volumevg
Without LVM, you might allocate all available disk space to the partitions you're creating, but with LVM, it is worthwhile to be conservative, allocating only part the available space to the current requirements.
As a general rule, it's easier to grow a filesystem than to shrink it, so it's a good strategy to allocate exactly what you need today, and leave the remaining space unallocated until your needs become clearer.
This method also gives you the option of creating new volumes when new needs arise (such as a separate encrypted file share for sensitive data).
Now you have several nicely named logical volumes at your disposal:
  /dev/fileserver/media
  /dev/fileserver/share
Summarizing where we are to this point - again, we have Logical Volumes over a Volume Group sitting on a Physical Volume Group spread over two Physical Drive Partitions - see below;
//The Logical Volumes//
<code>
test@testbox:~$ sudo lvdisplay
  --- Logical volume ---
  LV Path                /dev/fileserver/share
  LV Name                share
  VG Name                fileserver
  LV UUID                xNEcAi-Y4s6-mt9B-6ic6-iIOT-hN4i-gIkNg6
  LV Write Access        read/write
  LV Creation host, time testbox, 2016-05-20 22:25:42 -0700
  LV Status              available
  # open                 0
  LV Size                20.00 GiB
  Current LE             5120
  Segments               1
  Allocation             inherit
  Read ahead sectors     auto
  - currently set to     256
  Block device           252:0
  LV Path                /dev/fileserver/media
  LV Name                media
  VG Name                fileserver
  LV UUID                enRNSF-8awM-QQ73-q4mV-7vDu-s6mN-Vj9E3H
  LV Creation host, time testbox, 2016-05-20 22:26:08 -0700
  LV Status              available
  # open                 0
  LV Size                20.00 GiB
  Current LE             5120
  Segments               2
  Allocation             inherit
  Block device           252:1
</code>
//The Volume Group//
<code>
test@testbox:~$ sudo vgdisplay
  --- Volume group ---
  VG Name               fileserver
  System ID
  Format                lvm2
  Metadata Areas        2
  Metadata Sequence No  5
  VG Access             read/write
  VG Status             resizable
  MAX LV                0
  Cur LV                2
  Open LV               0
  Max PV                0
  Cur PV                2
  Act PV                2
  VG Size               59.62 GiB
  PE Size               4.00 MiB
  Total PE              15262
  Alloc PE / Size       10240 / 40.00 GiB
  Free  PE / Size       5022 / 19.62 GiB
  VG UUID               f5Z2w1-PSZi-9K3G-9RTp-1jNx-gj0q-WugTqD
</code>
//And the Physical Volume Group//
<code>
test@testbox:~$ sudo pvdisplay
  --- Physical volume ---
  PV Name               /dev/sdb1
  VG Name               fileserver
  PV Size               29.81 GiB / not usable 0
  Allocatable           yes (but full)
  PE Size               4.00 MiB
  Total PE              7631
  Free PE               0
  Allocated PE          7631
  PV UUID               zaNOx1-fS0k-wNQ1-DGpq-yfNg-kc3e-j5toa1
  PV Name               /dev/sdc1
  VG Name               fileserver
  Allocatable           yes
  PE Size               4.00 MiB
  Total PE              7631
  Free PE               5022
  Allocated PE          2609
  PV UUID               slUCwq-Gw81-FcbB-WF06-tt33-EQ27-9rT737
</code>
//Note - here's a hint that we've been quietly building quotas for the shares - not on a user basis, but on a share basis - and this keep linux from running off the end of the pier if it runs out of disk space - it'll panic a bit, but you won't crash the entire volume set, it'll go read-only if the limits are hit, which is a good indication to see what's going on - another reason why LVM is a good thing)//
Storage Part Seven
==== Mounting the Logical Volumes ====
Now to create mount points in the primary file system
  sudo mkdir /var/share
  sudo mkdir /var/media
Now we can test mount the logical volumes
  sudo mount /dev/fileserver/share /var/share
  sudo mount /dev/fileserver/media /var/media
you can check by doing a df -h and see that the file system has the new volumes and sizes
  /dev/mapper/fileserver-share   20G   44M   19G   1% /var/share
  /dev/mapper/fileserver-media   20G   33M   20G   1% /var/media
Finally, to persistently mount the file systems, first add the following lines to /etc/fstab:
  /dev/fileserver/share    /var/share      ext4   rw,noatime    0 0
  /dev/fileserver/media    /var/media      xfs   rw,noatime    0 0
And reboot the system
Storage Part Eight
==== Adding Reliability With RAID ====
So far, this LVM example has been reasonably straightforward.
That's right - it's a spanned drive, which is even more worrisome that a RAID0, as the read/write performance is limited to the speed of the drive within the span that data is being read from/written to, and there is no indication of any issues with the drive.
So let's convert our spanned drive to a RAID array
**First, any data that is in those logical volumes - back it up, as this is a destructive process;**
Second, if these are shared, stop any processes that might be using them
Then unmount the volumes
  umount /dev/fileserver/media
  umount /dev/fileserver/share
Check with df to make sure they're unmounted
Now we disassemble the sets... going it bit faster this time
  lvremove /dev/fileserver/media
  lvremove /dev/fileserver/share
  vgremove fileserver
  pvremove /dev/sdb1 /dev/sdc1
And we're back to two devices on the bus - by removing the LV's, we also remove the filesystem that overlaid them
Update the /etc/fstab and comment out the two LVM shares - we will be using the same two mounts after we build the array
**Setting up a Software RAID array**
Then, change the partition type on these two drives, using filesystem type fd (Linux raid autodetect) -
Delete the old partitions if needed, and create New Primary partitions - below we're setting up a RAID0, but you can change --level switch to 1,5,6,10 depending on number of disks, and you're intents.. this is only meant as an example.
Write the changes, and do an fdisk -l to check
  mdadm --create --verbose /dev/md0 --level=0 --raid-devices=2 /dev/sdb1 /dev/sdc1
And add it back to the LVM
Moving quickly
  pvcreate /dev/md0
  vgcreate fileserver /dev/md0
and you can verify that we're back to where we were...
  lvdisplay
Create the filesystem on the logical volumes
  mkfs.xfs /dev/fileserver/media
  mkfs.ext4 /dev/fileserver/media
Redo the mounts
check df to see that they're mounted - if good, go back and uncomment the lines for /var/share and /var/media in the /etc/fstab
Reboot, and you're set
Last part - Storage Part Nine
==== LVM advanced examples ====
LVM, like many other enterprise class technologies, brings new flexibility to the linux desktop.
While the previous walk-thru is small in scope, the real power of LVM is dealing with a large volume group, and being able to manage the Physical Volumes, Logical Volumes, and maintain your data.
=== LVM Growth ===
Suppose that over the next year, the storage system fills up and needs to be expanded. Initially, you can begin allocating the unallocated space.
In our previous example, we had a 59GB Volume Group (VG) and only 20GB allocated to /var/media - we can grow this out..
For instance, to increase the amount of space available for media files from 20GB to 25GB, run a command such as:
  lvextend -L25G /dev/fileserver/media
  xfs_growfs /dev/fileserver/media
Note that we're not increasing the size of /var/media, but the actual LVM logical volume that it's mounted from the Operating System, so the OS sees it, and uses it.
//Note - there is a -D switch on xfs_growfs, setting the limit in blocks (not bytes), if it is not set, then xfs_growfs will expand the filesystem to the limit of the volume.//
//**WARNING - one should __never__ reduce the size of an LVM Logical Volume, and xfs, while it can extend a partition/volume, it cannot shrink - to reduce the size of any partition on any filesystem, it's always a backup, and restore to the new volume size**//
=== Growth via MDADM - RAID ===
Leveling up - this is pretty complicated, but a structured approach works - takes time, and of course, always have a backup of your data...
//**WARNING - we're now mucking about deep inside the LVM stack - things might go wrong, may go wrong - so always, I repeat, always have a backup before doing operations like this**//
Let's say we have an LVM Logical Volume Group running on top of a RAID
As an example - we have 4 1TB drives running, and we want to swap them out for 4 4TB drives - we can do this. But it will take a bit of time to migrate and grow, as we do one disk at a time, and let MDADM sync the drives before going to the next disk in the arrary
Note - as a RAID5, 4*1TB = 3TB as we lose the 1TB for parity
Here's the lineup for the example - /dev/md0 is a member of the fileserver volume group (VG)
  The RAID5 device is /dev/md0
  The members of /dev/md0
  /dev/sdb1
  /dev/sdc1
  /dev/sdd1
  /dev/sde1
We first unmount the logical volumes across the entire LVM set.
With RAID5, the migration is straightforward, as we use RAID5's ability to run in degraded mode if we have a failed drive
Use mdadm to mark one single drive of the RAID5 mirrors as failed, and then remove it:
  mdadm --manage /dev/md0 --fail /dev/sda1
  mdadm --manage /dev/md0 --remove /dev/sda1
Pull out the sda hard drive and replace it with the new 4TB drive.
Go into fdisk, and partition the drive (see above) making sure to split the physical drive into two partitions, sda1 as the same size as the old 1TB sda1, and add new sda2 partion, which we add the remaining balance of sda to sda2 (approx 2.8TB)
Now we manage sda1 back to /dev/md0 - remember, that we marked sda1 as failed
  mdadm --manage /dev/md0 --add /dev/sda1
MDADM will then add /sda1 back to the array and start rebuilding the RAID5 set - once it's done, do the same with /sdb1 and so forth...
In the end of all this, we have 8 sets of partitions the sd<d,c,d,e>1 set, and the remainders - so we take the second set of partitions, and build that into a new /dev/md1 device
  mdadm --create --verbose /dev/md1 --level=5 --raid-devices=4 /dev/sdb2 /dev/sdc2 /dev/sdd2 /dev/sde2
So now we have a second MD RAID5 set - and this one is 12TB (remember that md0 is already 4TB recreated from the previous 4 1TB drives)
Let md1 finish it's sync up - can check mdstat to see the progress - when it's done...
we add them to the Physical Volume group (pv)
  pvcreate /dev/md1
and extend the volume group
  vgextend fileserver /dev/md1
Now the fileserver Volume Group has 12TB of storage compared to the previous 3TB of storage, and we can use LV to grow the file systems...
The previous allocations were 750GB for /share and 2TB for media, and now we want to put 3TB for /share, and 7TB /media (remember, we don't allocate the entire VG space to keep a bit in reserve)
  lvextend -L7T /dev/fileserver/media
  lvextend -L3T /dev/fileserver/share
And now we have 10TB of space - and we can grow the file systems according - and this is why xfs is much better than ext4
Mount the file systems again - as they were unmounted before we started swapping out disks...
Now we tell xfs to grow... but the filesystem must be mounted before we do this...
  xfx_growfs /dev/fileserver/share
And xfs will grow the filesystem to the extent of the volume.
What I'm getting at is that with LVM, we can definitely swizzle things around with Physical Volume, and Logical Volume all within the same Volume Group set - it's a very powerful solution, and one that enterprises use all the time.
Always do your homework, have a plan, and do some research - this is Linux after all, and changes happen and API's evolve - and always have a backup plan.
Lot of data to assimilate - but if you understand the Storage Section - this is what most Consumer/SME NAS boxes do under the hood...
The risks with LVM - it's very easy to create additional logical volumes, and LVM will do this... and logical volumes over time do tend to multiply - as do physical volumes below as we add more storage...
The downside is that if not planned, LVM can turn a good redundant array into an LVM striped array, depending how how the volume group is built... and there's a couple of very good articles on the main Smallnetbuilder.com website that get into this scenario...
Sidenote - I used XFS for most of the examples here - it's a great filesystem to use - well documented, and fully GPL and supported across many Linux Distributions.
It's not the only answer - obviously the default EXT3/EXT4 is a good thing, as is BTRFS (bit experimental, but getting BTR) and there's ZFS, which Ubuntu just added.
Thing is that with Linux (and the BSD's) there's a fair amount of abstraction between what you see when you do an "LS" and where that data actually lives.
The practical examples above - most were actually done with two USB 32GB thumb drives - so those physical disks might be a storage array, or some NFS mount a 1000 miles away, if you walk away understanding what we're doing here, you'll be pretty far ahead.
I also appreciate the effort you have put into this thread. When I first started following it encouraged me to purchase a Rasberry PI 3B just to see what the little box was capable of doing.
Well, I am totally amazed at it's performance thus far!
I've been pretty happy with the Pi2 so far - that little ARM processor can get a lot of things done.
Where it gets interesting is when one starts playing with a 'micro' network - pick up one of those TP-Link travel routers that support OpenWRT, and together they play very well.. can be a nice little network analysis box to do security audits, network tracing, etc... for example, running a kismet drone on the OpenWRT box, and Kismet on the Pi2... and the Pi2 has enough horsepower to process the data after the run.
Add a GPS receiver and a 3g modem to the Pi, and you've got a heck of a remote network toolbox ;)
Even with GUI the Pi 2 has enough power for standalone stuff. But that doesnt mean you cant get the pi 3 as What i like about it is that every new generation that comes out costs the same as the lasts when it came out just like what intel does.
Pi3 is a nice upgrade on the Pi2 - the software hasn't quite caught up with the new A53 cores, but A53 runs A7 code just fine, only faster ;)
That, along with the BTLE and WiFi onboard - if given a choice, the Pi3 would be the right one.
(if one can be found - they're still a bit in short supply)
Let's set up an VPN server - we'll use OpenVPN as it's commonly used in this community...
This section is a bit long - attaching it as a text file...
  • SNB Basics - Setup OpenVPN.txt
@sfx2000
I have installed OpenVPN per this tutorial on the Raspberry Pi 3 and configured an Android client on my cell phone. Happy to report it works very well. The Raspy Pi3 does sit behind my router, therefore I had to open the port required for the VPN server to make it work. - Thanks
@sfx2000
Reviewing my doku wiki I put together from the posts provided here I still have some unfinished contents. Specifically "Network Monitoring", "Monitoring", "Simple NAS Server" and "Extras".
Just wondering if I missed something or are they not quite finished yet? :)
@sfx2000
I've been busy with some work stuff now that I'm off my leave of absence - some of the contents at the root level have changed a bit, but I'll get back to this series shortly once I'm caught up with work...
Just v
Just caught onto this thread this week while I was pulling a RPi B2 out of storage to run a UniFi controller on (just bought an AP-AC-Pro). I have to admit being spoiled after building an ESXi whitebox server (Supermicro/Xeon E1230v2-based) a couple years ago, and that is usually where I do all my "tinkering" these days. But still nice to have dedicated hardware for a few things.
Now trying to decide what to do with the old original series B sitting in the drawer...or just retire it and buy a model 3 :)
Original B model - still useful - With Raspian - it's got all the Python goodies - and it's a great tool to learn Python on... if you're not a current "programmer/coder", then the link below is pretty cool...
http://learnpythonthehardway.org/book/index.html
Something to add to my "to-do" list...
To answer my question, I decided to test the UniFi controller backup/restore, so loaded it up on the B and installed it in the placed of the B2. Hint: change the Unifi init scripts to use Oracle 8 JDK vs openjdk.
The case I have for the B has a nicer system for wall mounting. I'm not using a captive portal, so don't really need the controller running full time, but in this case I can.
