DSL-AC68U, need QoS configuration advice
emr8989
Friends, I have Asus DSL-AC68U device. I want to fix the bufferbloat values on this device.
Merlin is installed on the device. QoS is not working as I want. "Cake" is recommended by everyone in SQM structures but there is no such option in my panel.
Is there any other way to install a smart queuing system on this device?
Cake needs newer kernel, your available options are Adaptive QoS and Traditional QoS.
Use what you have, test available options, see how it goes with what you normally do on Internet. If you test bufferbloat with online test sites - don't. The test saturates your connection and creates bufferbloat conditions, something you normally don't do with normal use.
