Dual Wan Failover - Individual WAN VLAN settings needed
geobernd
I have been ripping my hair out for the last two hours or so (ok - not much hair left anyway...) and hope someone here is smarter than me:
I am trying to setup Dual WAN Failover (either the native Asus method or the Dual WAN Failover Script posted in another thread here).
My Problem is:
The regular WAN is Quantum Fiber which requires VLAN 201 (set in LAN-IPTV as Internet VID 201)
The backup WAN is Comcast - which only connect with no VLAN ID.
I can get one or the other working at a time by changing the VLAN ID in the LAN settings but not both...
I looked at the nvram stuff and figure out if there is a way to set it differently there but can always only find one interface reference:
With VLAN set
igmp_ifname=vlan201
wan0_gw_ifname=vlan201
wan0_ifname=vlan201
wan_ifnames=vlan201
With no VLAN set
wan0_gw_ifname=eth0
wan0_ifname=eth0
I see entries for wan1 but they don't seem to correspond to what I am using - maybe I am not looking right...
Hoping one of our great community here has come across this before (I tried search but came up empty) and has a solution. I am happy making a custom jffs script etc...
Just realized I forgot some details:
I am using a RT-AX86U running Asuswrt-Merlin 386.7 and connecting one WAN on the 1Gig Port and the other one on the 2.5Gig Port...
My Problem is:
With VLAN set
igmp_ifname=vlan201
wan0_ifname=vlan201
wan_ifnames=vlan201
With no VLAN set
wan0_gw_ifname=eth0
wan0_ifname=eth0
Are you saying you already tried assigning VLAN ID using IPTV Settings under LAN Tab? It sounds like you need to set it like this and reboot.
EDIT: FYI I'm the author of the Dual WAN Failover Script.
Thanks Ranger for the reply
Yes - I have assigned the VLAN ID just as your screenshot shows - the problem is it is then applied to the primary and secondary WAN and the secondary only works without a VLAN ID - but I think I just solved it for me:
On a hunch - after looking at the nvram variables again - and still only seeing the VLAN ID on wan0 - I switched the secondary WAN to Ethernet LAN Port 4 instead of one of the WAN Ports and it is working now: The LAN port does not get the VLAN ID applied so I get an IP Address and traffic flow when falling over.
Of course as you wrote in the script threat the ASUS failover/fallback did not work properly for me (no fallback) so I just installed your script and tested failover/fallback and its looking good!
I'll monitor for a little bit and do a couple more test today and will actively start watching the script thread.
Thank you for the great work
Yay - Connected:
Yay - Connected:
Can you post in that thread regarding your success with the script and what version you are running? Awesome!
