Ethernet Port Status -AX92U- FW 3.0.0.4.388_23630-g9d6ee22
scootertramp
Since upgrading firmware to 3.0.0.4.388_23630-g9d6ee22 from 3.0.0.4.388.22525 two weeks ago I
do not see the correct status for my ethernet ports on the Web App. Currently they show yellow with 0 Mbps.
With the previous firmware they correctly showed green and 1 Gbps.
Oddly they display a little different on the Phone App. Status is green but connection is still 0 Mbps.
Anyone else seeing this or have any insights.
It's an old bug which was fixed recently for other routers. Wait for fix in next firmware.
There likely wont be another firmware. The AX92U is now listed as End Of Life on Asus website.
I also have that issue.
Unfortunately this is how corporations tricks you into buying new products. Hope I'm wrong and they issue a firmware update to fix this, it's still a pretty robust router.
