GT-AX6000 Merlin 388.2_2 2.4GHz not able to turn off broadcast
BeachGuy
I'm not sure if this is the correct place to report a bug but I flashed a new router (GT-AX6000) with Merlin 388.2_2. After following suggestions on flashing and updating properly, I tried to turn off 2.4GHz radio (Wireless: Professional). Clients can still connect however there is no internet. I have it "hidden" through the Wireless: general tab. Concerned that it might be a bug with the firmware. Others have said the router may be bad and return it but before I do that I wanted to get programmer's (RMerlin?) thoughts. Thanks
Ok I did a hard reset and flashed ASUSWRT 3.0.0.6_102_21514. Disabled radio on 2.4GHz and ssid didn't show in clients. Did a hard reset, Flashed Merlin 388.2_2 and disabled radio on 2.4GHz and ssid is not showing in clients. Note to self, always do a hard reset before flashing.
Thanks Tech9 and L&LD!
As noted in the other thread, do a full/proper reset AFTER flashing the firmware you want to use/test.
Before you do the above (and you want to quickly get your router/network back to where it is now):
Screenshots on their own are useless.
Use a text file or create those screenshots as PDFs so you can copy/paste from it to the router.
Reconfiguring isn't a PITA vs. the alternative (unstable/unreliable network). 15 minutes worth of time or so isn't much 'work'.
You're right. A properly configured network is worth it. Just been flashing/configuring for the last few days. I like the idea of PDF, I will do that. Thanks for all your help!
I flashed 3004.388.4_0, then did factory reset with initialize all settings and just noticed that 2.4Ghz is broadcasting again. Is there a particular order this should be done? I can't disable 2.4Ghz radio. I saw the following thread but nobody really answered him.
I found the following on a forum...
disable ssid broadcasting" will disable only the sending of some
information, but the router will still broadcast a radio signal.
I want to turn off the brodacasting completely
About 1/2 way down:
