GT-AXE-11000 not connecting consistently to 5G...
Pupster
Have a new GT-AXE-11000 router (less than a month old), and while the 5G was connecting reliably at first, now it frequently disappears when I browse for the SSIDs from my various wireless devices. When the 5G does show up, it fails to connect (the computer will show "connecting," and then it ultimately errors out.
I upgraded to the latest firmware before I started having all these problems. Could that be the problem? 3.0.0.386_43984
Unfortunately, I didn't record the firmware version before I autoupgraded to the latest firmware, so even if I can flash back to the older firmware, I don't know what version to flash back to....
Could there be another reason the 5G appears then disappears and is erractic? Hate that I spent $600 on a doorstop....
What are your WIFI settings?
Are you using 160 MHz bandwidth and what channel are you using? If so, switch to 80 MHz. You could be being affected by DFS radar scans.
