Hey everybody. I've been trying to figure out how to get my computer to disconnect from the OpenVPN client I set up using the scripts provided in the linked guide below. Everything seems to be working just fine, but the last optional step involving creating an additional batch file to disconnect from the VPN without logging into the router or rebooting my computer I'm having a lot of trouble with. I filled out all the appropriate technical information in the batch file based on the guide, but whenever I run it and select local ISP it instead decides to stay on the VPN. I'm not sure what it is I'm doing wrong, so any help would be much appreciated. Like I said earlier, everything else appears to be working just fine. All the devices I want on the VPN are on it and all the others I don't want on it aren't. It's just this last bit that's giving me some issues.
By the way, I'm not very tech savvy (far from it, in fact), so if there's any key information I didn't happen to provide then please let me know and I'll try my best to include it in my next post. Thanks in advance.
https://github.com/RMerl/asuswrt-me...ver-VPN-and-Drop-connections-if-VPN-goes-down
