Prevent SSH Disconnect / Timeout around ~ 105-116 seconds from last activity on terminal session
rjsh
Disconnecting SSH session when there is no activity for ~ 105-116 seconds. Want this behavior changed so it doesn't timeout for 20 minutes but not sure how or where to make a change. Am sure I am missing somethng obvious but I can't figure it out. Thx.
Rebooted the router to make sure someothing wasn't going wonky and same behavior persists.
Via the UI below are the settings I have:
- Administration > System > Basic Config > Auto Logout: 30 mins
- Administration > System > Service > Enable SSH: LAN only
- Administration > System > Service > Allow SSH Port Forwarding: NO
- Administration > System > Service > Allow Password Login: YES
- Administration > System > Service > Authorized Keys: <redacted>
- Administration > System > Service > Enable SSH Brute Force Protection: YES
- Administration > System > Service > Idle Timeout: 20 minutes
- Administration > System > Remote Access Config > Enable Web Access from WAN: NO
- Administration > System > Remote Access Config > Enable Access Restrictions: NO
From the System Messages Log (showing the connect via ssh and the auto disconnect)
Feb 27 13:44:52 RT-AC68UTM dropbear[11893]: Password auth succeeded for 'rjsh' from 192.168.1.148:51186
Feb 27 13:46:48 RT-AC68UTM dropbear[11893]: Exit (rjsh): Exited normally
Also have Skynet, Scribe, scMerlin, spdMerlin, YazDHCP installed.
FYI locally I've got my .ssh/config setup with:
TCPKeepAlive=yes
ServerAliveInterval=15
ServerAliveCountMax=6
Compression=yes
UPDATE:
When I changed config file: ServerAliveInterval=60, The connection lasts for ~ 60seconds * 6 (ServerAliveCountMax) and then disconnects (~ 360 seconds)
This older thread helped: https://www.snbforums.com/threads/dropbear-timeout.22588/
TCPKeepAlive=yes
Compression=yes
UPDATE:
Thanks - this at least will disconnect my end of the session - the router side shell is not respecting the TMOUT value any longer
Is this on the client side (or on your router)?
I have this on the client side (macOS):
  ServerAliveInterval 60
  ServerAliveCountMax 10
This seems to work well for my Raspberry Pi's, but not for my router (GT-AX6000, running AsuswrtMerlin 388.6_2).
Yeah, this is client side - not router. The router file name is ssh_config or something and that file is empty and can't be edited. I think you need this option too: TCPKeepAlive=yes
There is no ssh_config file on the router because it doesn't run an OpenSSH server. It runs dropbear with the idle timeout being "never".
What does the "Idle timeout" field on the Admin/System page do?
It's set to 20 minutes by default, but my ssh sessions never time out.
My SSH sessions to the router get terminated before that 20 minute value…
It's the busybox shell timeout value set in $TMOUT. That's subtlety different than an SSH server (e.g. dropbear) timeout.
However, it looks like that option has not been enabled in busybox rendering the GUI option pointless. It's enabled in John's fork but not Merlin's for some reason.
@RMerlin ?
