derril
Hello guys! I've recently acquired a GT-AX6000 router and i would like to know if netem package is available and function properly. I am trying to add artificial latency for both testing purposes and gaming as well. If the package is not available is there any tutorial on how i could get this thing running? I am coming from an EdgeRouter6P where it was pretty easy to do it with the following commands:
Increase latency: sudo tc qdisc add dev eth0 root netem delay 20ms
Remove latency: sudo tc qdisc del dev eth0 root netem
It also works perfectly fine on OPNsense routers using ipfw.
