Daveo
How do I remove and replace my Skynet filter lists with @SomeWhereOverTheRainBow list (https://raw.githubusercontent.com/jumpsmm7/GeneratedAdblock/master/filter.list) ?
refer to this postHow do I remove and replace my Skynet filter lists with @SomeWhereOverTheRainBow list (https://raw.githubusercontent.com/jumpsmm7/GeneratedAdblock/master/filter.list) ?
curl: option -0z: requires parameter
is displayed when trying to consolidate blacklistsworks fine for me.When i try and use the filter list above in post 342, an errorcurl: option -0z: requires parameter
I need an automatic copy of your list . It has been awhile since I last checked forumSo your logic was correct on this, @chongnt ... I cross-referenced entries from list 8.txt, and they were all contained within 3.txt. I've adjusted my filter list accordingly to prevent skynet from having to download and process dupes, which should save a few seconds on processing time. Thanks again!
I update the list contents directly on github... Just use this link as your custom filter list in skynet.I need an automatic copy of your list . It has been awhile since I last checked forum
You forgetting that I plagiarist your list to add my one and only url lolI update the list contents directly on github... Just use this link as your custom filter list in skynet.
LOL don't we all, right?You forgetting that I plagiarist your list to add my one and only url lol
Rebooted the router and now it workes fine, oddworks fine for me.
Many thanks. I have now successfully switchover to your filter list for Skynetrefer to this post
Skynet - Is default firewall good enough?
I typically run a check against it's IP on AlienVault if something looks suspicious or just to spot check... https://otx.alienvault.com/indicator/ip/205.185.216.10 I typically do such if I find something not regularly blocked is now being blocked.www.snbforums.com
Where do I enter this whitelist? I've been looking at every menu item but cannot locate it. (Am I blind or just dumb?)
You might not be able to import it because I think it is too big.
It is under import list option. You select the whitelist option as the type of option then you copy paste the url into the terminal.Where do I enter this whitelist? I've been looking at every menu item but cannot locate it. (Am I blind or just dumb?)
Ah I see, so this one needs updating manually, correct? Instead of the blacklist that's taken care of via the Malware Blacklist option.It is under import list option. You select the whitelist option as the type of option then you copy paste the url into the terminal.
Or you can just type it into the terminal following these set of directions.
Example Import Commands;
( firewall import blacklist file.txt "Apples" ) This Bans All IPs From URL/Local File With The Comment Apples
( firewall import whitelist file.txt "Apples" ) This Whitelists All IPs From URL/Local File With The Comment Apples
It is too big.
That depends on if you are ever concerned about running into false positives. Numerous websites/web services use the same IP addresses. False positives could range from your banking app or bank website to your favorite online game servers. Or in most extreme situations, country blocking could mean you need to allowlist root servers for unbound. It is very hard to say if skynets "hardcoded" whitelist is good enough since it was made with only consideration of the default skynet filter list. Whether you need to allow list IP's and domains depends on your personal use.It is too big.
Is the hardcoded whitelist good enough in Skynet?
Looks like it's happened to the @Viktor Jaep list as well, showing zero ranges also.that thing happened again ….
Thread starter | Title | Forum | Replies | Date |
Solved Customize default System Log | General Log web page with grep? | Asuswrt-Merlin AddOns | 5 | ||
Skynet Skynet 7.5.8 Firewall UI Issues | Asuswrt-Merlin AddOns | 19 |
Welcome To SNBForums
