LEDs keep coming back on
Grimm
Anybody having same problem when using AiMesh system. I keep having to toggle the LEDs Off in the nodes. I have 2 systems running, and both separate nodes keep switching the LEDs of the router back on. Upon checking they are still switched off, so i need to switch on and back off to switch them off again.
All 4 Routers RTAC86U 2 separate networks, only the nodes have the LED problem.
black tape next :)-
I have had this issue from day one on RT-AX86s
Setup as mesh node
I just installed the latest 888 firmware and they are staying off now
I've been watching this happen on my ax88u and have come to my own conclusion. By studying the logs it seems the LEDs get reactivated when something changes on the LAN or wifi - not disconnects but more like when the WiFi group key refreshes, or the lease renews, or a channel change. It can also be triggered by making serious changes to the lan or wifi settings.
Just what I'm seeing. Using lc under amtm will permanently deactivate the LEDs and even retain the setting over a reboot.
Could try the amtm led controller script ?
P Are there no new (smaller) AXE wifi 6e routers coming out for Asus? ASUS Wireless 32
