Loaded the nat-start scripts under /jffs/scripts, but still not able to execute. Already granted 777 permission. Tried manually execute by /jffs/scripts/nat-start in PuTTY, but error message of "nat-start not found". Seems the file of nat-start is not able to be executed, but not sure why.
Here are some commands I run.
admin@RT-AC68U-F000:/jffs/scripts# ls -l
-rwxrwxrwx 1 admin root 123 Apr 23 22:49 nat-start
admin@RT-AC68U-F000:/tmp/home/root# /jffs/scripts/nat-start
-sh: /jffs/scripts/nat-start: not found
From the system log, it seems the nat-start was called. But the setting wasn't triggered, so it didn't execute.
custom_script: Running /jffs/scripts/nat-start
Also attached the scripts in nat-start:
admin@RT-AC68U-F000:/tmp/home/root# cat /jffs/scripts/nat-start
#!/bin/sh
iptables -t mangle -A POSTROUTING -j TTL --ttl-set 65
#!/bin/sh
