Not getting full speed with Asus RT-AC86U
IsaiahHanson
Hello all!
I was wondering if anyone knows what I should do to get my full download speed from my Asus RT-86U router. I've tried the recommendations on these 2 forums:
https://www.snbforums.com/threads/asus-rt-ac86u-not-getting-maximum-speeds-on-gigabit-fibre.50402/
https://www.snbforums.com/threads/rt-ac86u-3-0-0-4-382-16466-ctf-and-fa-missing.41739/
With no luck.
Router Firmware is 3.0.0.4.386_51529
QOS is disabled
I disabled and re-enabled Runner in SSH
FC is enabled.
Any ideas on what it might be?
I should be 500 down, but am only getting 200.
Go to the “Administration” -> “Privacy” tab in the GUI, and click all the Withdraw button(s) visible, then reboot. Any improvement?
SSID: "router 2.4"
noise: -88 dBm Channel: 10
BSSID: D4:5D:64:0B:B7:58 Capability: ESS ShortSlot RRM
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
VHT Capable:
Chanspec: 2.4GHz channel 10 20MHz (0x100a)
Primary channel: 10
HT Capabilities:
Supported HT MCS : 0-7
Supported VHT MCS:
NSS1 Tx: 0-11 Rx: 0-11
Interference Level: Acceptable
Mode : AP Only
Stations List
idx MAC Associated Authorized RSSI PHY PSM SGI STBC MUBF NSS Tx rate Rx rate Connect Time
SSID: "router 5"
noise: -87 dBm Channel: 44/80
BSSID: D4:5D:64:0B:B7:5C Capability: ESS RRM
Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
VHT Capable:
Chanspec: 5GHz channel 42 80MHz (0xe22a)
Primary channel: 44
HT Capabilities:
Supported VHT MCS:
NSS2 Tx: 0-9 Rx: 0-9
NSS3 Tx: 0-9 Rx: 0-9
NSS4 Tx: 0-9 Rx: 0-9
Mode : AP Only
DFS status: state IDLE time elapsed 0ms radar channel cleared by DFS none
Channel Information
Channel 36 A Band
Channel 40 A Band
Channel 44 A Band
Channel 48 A Band
Channel 52 A Band, RADAR Sensitive, Passive
Channel 56 A Band, RADAR Sensitive, Passive
Channel 60 A Band, RADAR Sensitive, Passive
Channel 64 A Band, RADAR Sensitive, Passive
Channel 100 A Band, RADAR Sensitive, Passive
Channel 104 A Band, RADAR Sensitive, Passive
Channel 108 A Band, RADAR Sensitive, Passive
Channel 112 A Band, RADAR Sensitive, Passive
Channel 116 A Band, RADAR Sensitive, Passive
Channel 132 A Band, RADAR Sensitive, Passive
Channel 136 A Band, RADAR Sensitive, Passive
Channel 140 A Band, RADAR Sensitive, Passive
Channel 149 A Band
Channel 153 A Band
Channel 157 A Band
Channel 161 A Band
Channel 165 A Band
Stations List
78:D2:94:37:7E:39 Yes Yes -30dBm ac No Yes Yes No 1 433.3M 117M 00:03:36
BA:F3:31:51:2E:BC Yes Yes -44dBm ac Yes Yes No No 1 433.3M 24M 00:16:22
CA:BA:0D:62:32:27 Yes Yes -56dBm ac Yes Yes No No 1 390M 24M 00:25:49
Stations List
All 3 clients have only 1 stream, with 433 Mb max rate. Cut that number in half due to the realities of WiFi, and you get around 200 Mbit.
WiFi isn’t my specialty, so others may correct me or offer further insights.
SSID: "router 2.4"
VHT Capable:
Primary channel: 10
HT Capabilities:
Supported VHT MCS:
Mode : AP Only
Stations List
SSID: "router 5"
VHT Capable:
Primary channel: 44
HT Capabilities:
Supported VHT MCS:
Mode : AP Only
Channel Information
Channel 36 A Band
Channel 40 A Band
Channel 44 A Band
Channel 48 A Band
Channel 149 A Band
Channel 153 A Band
Channel 157 A Band
Channel 161 A Band
Channel 165 A Band
Stations List
What are those three AC clients
Windows, iPhone, and ?
TX rates look like 2.4
In the gui, network map tab left side, click view list, sort by interface.
Where are the clients connected
Change your WiFi 5 channel from 44 to 157 and see if your 433.3 changes to 866
May want to reboot the router after making that change just to be sure.
Devices with 1-stream radio or Router with Power Save mode activated (App or GUI).
This is unlikely to be the problem. See one of the devices is literally next to the router at -30dBm.
Good catch on possible router power save mode, definitely check
Discovered by accident when playing with Asus App, but the power slide in Professional to Power Save does the same thing.
Internet access stateDevice TypeClient NameClient IP addressIP MethodClients MAC AddressInterfaceTx RateRx RateAccess time
Allow Internet accessSamsung Electronics Co. Ltd.Samsung192.168.50.10Automatic IPD0:C2:4E:54:8A:005 GHz
433.3​
6​
0:24:56​
Allow Internet accessLoading manufacturer..BA:F3:31:51:2E:BC192.168.50.101Automatic IPBA:F3:31:51:2E:BC5 GHz
433.3​
351​
0:27:46​
Allow Internet accessMSFT 5.0DESKTOP-1BVNML8192.168.50.102Automatic IP54:8C:A0:A3:EB:C35 GHz
263.2​
292.5​
0:24:03​
Allow Internet accessLoading manufacturer..CA:BA:0D:62:32:27192.168.50.104Automatic IPCA:BA:0D:62:32:275 GHz
390​
24​
0:28:05​
Allow Internet accessMSFT 5.0DESKTOP-ISAIAH192.168.50.218Automatic IP78:D2:94:37:7E:395 GHz
433.3​
6​
1:17:52
433.3​
6​
0:24:56​
433.3​
351​
0:27:46​
263.2​
292.5​
0:24:03​
390​
24​
0:28:05​
433.3​
6​
1:17:52​
So, basically, 2 iphones, 2 windows 11 devices, and a samsung tv
Where in the GUI would find this?
If you can't get the TX rate above 433 you're going to be limited to about 200-250M of throughput. Either the radio in your router is dying or some setting got messed up somewhere. When was the last time you did a factory reset and reconfigure by hand?
I have not a done a factory reset ever. Is that the next step?
Definitely. Look up the "hard reset" method for your router. Copy down your settings (screen captures or copy/paste to a document as needed) and re-enter just what you need manually, not from a backup.
Update to the latest firmware before hard resetting too, might as well while you're at it.
The only things I'd tweak from default to start is disable universal beamforming on both wireless bands under advanced. You can customize IP, DHCP, etc settings if you need to but leave other wireless stuff at default, don't enable trend micro, etc. Start with a baseline and see how it looks, then add/enable other stuff as needed.
