The command is nvram get clkfreq
That shows the nvram value, but that won't necessarily show what has been applied to the hardware.
I don't know any way to read the value that's actually programmed in the memory controler.
Technically, 1000,800 should not be called overclocking as it is within the specs of our hardware.
Broadcom has three different SKUs for the BC470x line. I don't think they all clock to 1 GHz - in fact I believe that's one of the differences between the BCM4708 and BCM4709.
Good point. Published Broadcom specs are not very clear IMO...
So R7K owners are safe at 1GHz?
Either way, what happened to Primitivo's router is a concern. Corrupted NVRAM?
So the router was running for a while at 1000,800 and one day it just died? Or it died right after applying the clocks?
Also, other firmware like DDWRT and Tomato can show ram frequency and such, so wouldn't be the same command or code?
Merlin - please correct me - is 1000/800 kosher (not saying it is not, just asking)?
Nothing else but the stock clock is safe. For example, you don't know if Asus is undervolting the RAM since they run it at a lower clock.
Very good point. Overclocking is not only science, but in many cases just luck.
Some chips run fine while undervolted, and some with crap out.
This whole discussion makes the decision between getting AC68U vs Netgear R7K (which seems by all means faster than ASUS) very painful...![]()
I doubt that DD-WRT's implementation of OpenVPN on a 1 GHz R7000 will give you any significant performance boost over my own implementation on a 800 MHz RT-AC56U. I wouldn't be surprised if it was actually slower, due to lack of CTF, not having the various optimizations I did to openssl and openvpn, etc...
playing with CPU/memory clocks should not have any effect on the wifi... could be weird coincidence or something is gone wrong.
speedingcheetah - if 1000/800 was stable for you and you did not have any issues, and temps are in check, I really do not see a reason why should downlock the memory. If I am not mistaken - you were fine with 1000/800, and all you issues started when you went 1000/667?
Mini rant: I will never use another Netgear router again. I have nothing but problems and failures...not to mention numerous bricks with the Netgear routers that I have flashed custom firmware to.
Also, Dlink....their customer service is a joke...and they refuse to accept any RMA I have submitted...claiming they haven't received any of the needed information, despite my several email replies to their messages. DLink also claim they will charge you if you don't send back all the org accessorizes(pwr cord, ethernet cord, QIG and cd)...ridiculous.![]()
Welcome To SNBForums
