Rebooting AiMesh Node Command.
archiel
I am looking for the correct command to force a reboot of the AiMesh Node (RT-AX58U) directly from the Router (RT-AX88U) so that I can add it as a cru instruction. I can see that I can do this from the GUI (AIMESH>Node>Management>Reboot) and want to trigger this automatically.
Background: I am using Channelhog to reset the router when it drops the 5 GHz signal from 160MHz to 80, which happens a couple of times a week. However either the Node does not pickup the change or, if it does, it is switching to 2.4Ghz as the 5 GHz channel is waiting for clearance. As such I would like to reboot the node about 1 hour after Channelhog has run (to give everything on the router time to settle down). I am running asuswrt on the node, as running merlin was problematic (even after full factory reset), so I do not have access to the reboot scheduler in amtm.
