pete y testing
hi guys
have the above setup and has enabled link bonding in the 88u and setup bonding in the 415+ but im not seeing any extra throughput
have 1 ethernet connected comp that can download at 117 MB/s
if i start a second download on a different ethernet connected comp of the same file the first slows to about 70 MB/s and the second 40MB/s
so its apparent the bonding isnt working
the 415+ is set for
IEEE 802.3ad dynamic link aggregation
see
https://www.synology.com/en-global/...p/DSM/AdminCenter/connection_network_linkaggr
or is there a different setting i should use
hdd are setup in jbod mode
pete
the 415+ is set for
see
pete
