RT-AX58U transmission client crashes when adding torrent files
don11995
Hello! I am on AsuswrtMerlin 3004.388.5 firmware and router ASUS RT-AX58U. I am using it as a NAS server in my local network. Also, I am using Download Master for some torrent files. After adding some torrent files the DM started to crash with messages in log like this repeatedly:
Jan  8 19:20:04 kernel: potentially unexpected fatal signal 11.
Jan  8 19:20:04 kernel: CPU: 0 PID: 31072 Comm: dm2_transmissio Tainted: P           O    4.1.52 #1
Jan  8 19:20:04 kernel: Hardware name: Generic DT based system
Jan  8 19:20:04 kernel: task: cdd98400 ti: ce7a8000 task.ti: ce7a8000
Jan  8 19:20:04 kernel: PC is at 0xb6b73d44
Jan  8 19:20:04 kernel: LR is at 0x2f6ac
Jan  8 19:20:04 kernel: pc : [<b6b73d44>]    lr : [<0002f6ac>]    psr: 20000010
Jan  8 19:20:04 kernel: sp : b6914760  ip : 0008f570  fp : b69148f4
Jan  8 19:20:04 kernel: r10: 004d53e0  r9 : 004cc0e0  r8 : 24ac702b
Jan  8 19:20:04 kernel: r7 : 004d56e8  r6 : 00000000  r5 : 004d53e8  r4 : 00510420
Jan  8 19:20:04 kernel: r3 : 00000001  r2 : 004ccc68  r1 : 00000000  r0 : 00000000
Jan  8 19:20:04 kernel: Flags: nzCv  IRQs on  FIQs on  Mode USER_32  ISA ARM  Segment user
Jan  8 19:20:04 kernel: Control: 10c5387d  Table: 0e61004a  DAC: 00000015
Jan  8 19:20:04 kernel: [<c0026f20>] (unwind_backtrace) from [<c0022cf8>] (show_stack+0x10/0x14)
Jan  8 19:20:04 kernel: [<c0022cf8>] (show_stack) from [<c045ba7c>] (dump_stack+0x8c/0xa0)
Jan  8 19:20:04 kernel: [<c045ba7c>] (dump_stack) from [<c003ab8c>] (get_signal+0x490/0x558)
Jan  8 19:20:04 kernel: [<c003ab8c>] (get_signal) from [<c0022290>] (do_signal+0xc8/0x3ac)
Jan  8 19:20:04 kernel: [<c0022290>] (do_signal) from [<c0022718>] (do_work_pending+0x94/0xa4)
Jan  8 19:20:04 kernel: [<c0022718>] (do_work_pending) from [<c001f58c>] (work_pending+0xc/0x20)
Jan  8 19:20:07 kernel: potentially unexpected fatal signal 11.
Jan  8 19:20:07 kernel: CPU: 1 PID: 31116 Comm: dm2_transmissio Tainted: P           O    4.1.52 #1
Jan  8 19:20:07 kernel: Hardware name: Generic DT based system
Jan  8 19:20:07 kernel: task: ce432000 ti: cdd6e000 task.ti: cdd6e000
Jan  8 19:20:07 kernel: PC is at 0xb6b79d44
Jan  8 19:20:07 kernel: LR is at 0x2f6ac
Jan  8 19:20:07 kernel: pc : [<b6b79d44>]    lr : [<0002f6ac>]    psr: 20000010
Jan  8 19:20:07 kernel: sp : b691aa78  ip : 0008f570  fp : b691ac0c
Jan  8 19:20:07 kernel: r10: 01e33be8  r9 : 01e2b0e0  r8 : 24ac702b
Jan  8 19:20:07 kernel: r7 : 01e33ef0  r6 : 00000000  r5 : 01e33bf0  r4 : 01e393c0
Jan  8 19:20:07 kernel: r3 : 00000001  r2 : 01e2bc68  r1 : 00000000  r0 : 00000000
Jan  8 19:20:07 kernel: Flags: nzCv  IRQs on  FIQs on  Mode USER_32  ISA ARM  Segment user
Jan  8 19:20:07 kernel: Control: 10c5387d  Table: 0e61004a  DAC: 00000015
Jan  8 19:20:07 kernel: [<c0026f20>] (unwind_backtrace) from [<c0022cf8>] (show_stack+0x10/0x14)
Jan  8 19:20:07 kernel: [<c0022cf8>] (show_stack) from [<c045ba7c>] (dump_stack+0x8c/0xa0)
Jan  8 19:20:07 kernel: [<c045ba7c>] (dump_stack) from [<c003ab8c>] (get_signal+0x490/0x558)
Jan  8 19:20:07 kernel: [<c003ab8c>] (get_signal) from [<c0022290>] (do_signal+0xc8/0x3ac)
Jan  8 19:20:07 kernel: [<c0022290>] (do_signal) from [<c0022718>] (do_work_pending+0x94/0xa4)
Jan  8 19:20:07 kernel: [<c0022718>] (do_work_pending) from [<c001f58c>] (work_pending+0xc/0x20)
Jan  8 19:20:08 kernel: potentially unexpected fatal signal 11.
Jan  8 19:20:08 kernel: CPU: 0 PID: 31127 Comm: dm_print_status Tainted: P           O    4.1.52 #1
Jan  8 19:20:08 kernel: Hardware name: Generic DT based system
Jan  8 19:20:08 kernel: task: ce1d0800 ti: d932c000 task.ti: d932c000
Jan  8 19:20:08 kernel: PC is at 0xb6f3ad44
Jan  8 19:20:08 kernel: LR is at 0x131a0
Jan  8 19:20:08 kernel: pc : [<b6f3ad44>]    lr : [<000131a0>]    psr: 20000010
Jan  8 19:20:08 kernel: sp : bef3aea8  ip : 000311d8  fp : bef3ba34
Jan  8 19:20:08 kernel: r10: b6fbaf6c  r9 : 00000000  r8 : 00000000
Jan  8 19:20:08 kernel: r7 : 00000000  r6 : 00011014  r5 : 00000000  r4 : bef3c08b
Jan  8 19:20:08 kernel: r3 : 00000000  r2 : 000201c4  r1 : 00000000  r0 : 00000000
Jan  8 19:20:08 kernel: Flags: nzCv  IRQs on  FIQs on  Mode USER_32  ISA ARM  Segment user
Jan  8 19:20:08 kernel: Control: 10c5387d  Table: 0e7d404a  DAC: 00000015
Jan  8 19:20:08 kernel: [<c0026f20>] (unwind_backtrace) from [<c0022cf8>] (show_stack+0x10/0x14)
Jan  8 19:20:08 kernel: [<c0022cf8>] (show_stack) from [<c045ba7c>] (dump_stack+0x8c/0xa0)
Jan  8 19:20:08 kernel: [<c045ba7c>] (dump_stack) from [<c003ab8c>] (get_signal+0x490/0x558)
Jan  8 19:20:08 kernel: [<c003ab8c>] (get_signal) from [<c0022290>] (do_signal+0xc8/0x3ac)
Jan  8 19:20:08 kernel: [<c0022290>] (do_signal) from [<c0022718>] (do_work_pending+0x94/0xa4)
Jan  8 19:20:08 kernel: [<c0022718>] (do_work_pending) from [<c001f58c>] (work_pending+0xc/0x20)
Jan  8 19:20:11 kernel: potentially unexpected fatal signal 11.
I tried fully reinstalling and reformatting the drive - but nothing helped. Also, there is a link to a torrent file example with which the DM is crashing: https://drive.google.com/file/d/1xbsR6J3eu1GJHO1YSBgUGf4pFEGUZHXl/view?usp=drive_link
Just add this file, choose all files to download and DM will start to crash in a loop.
Does anyone know what the problem is and how to solve it? Thank You.
There was a similar thread recently that sounded like this. Don't remember if a solution was found. Seek it out.
I found that thread before creating this. It was said that I need to rename the torrent file to avoid any whitespaces in its name. But this did not help at all.
