RT-AX86U - log entry changes from FEB to MAY for 6 seconds?
delikid
I just upgraded to 3004_388.6_2 on my RT-AX86U. I checked the logs just to see if there was anything to see and found that something is going on that a device (the router?) is using the date of May 5!
If you look at the log entries below, on line 19 an action starts May 5 01:05:09 and ends on May 5 01:05:15. The actions continue for 6 seconds but is doing of ton of action in that time. Then it switches back to Feb 28. Can anyone shed some light on this? Why is it changing the date to May 5 then back to today?
Feb 28 15:56:08 kernel: CSIMON:  CSIMON[1.1.0] Initialization
Feb 28 15:56:08 kernel: CSIMON: M2M usr already registered ...
Feb 28 15:56:12 kernel: ^[[0;33;41m[ERROR pktrunner] runnerUcast_inet6addr_event,148: Could not rdpa_system_ipv6_host_address_table_find ret=-5^[[0m
Feb 28 15:56:13 kernel: port_generic_stop 564 skip turnning off power on eth4 here
Feb 28 15:56:13 kernel: port_generic_stop 564 skip turnning off power on eth3 here
Feb 28 15:56:13 kernel: port_generic_stop 564 skip turnning off power on eth2 here
Feb 28 15:56:13 kernel: port_generic_stop 564 skip turnning off power on eth1 here
Feb 28 15:56:13 kernel: port_generic_stop 564 skip turnning off power on eth5 here
May  5 01:05:09 kernel: CPU: AArch64 Processor [420f1000] revision 0
May  5 01:05:09 kernel: Do not need to create mapping for reserved memory phys 0x000000000e000000 virt 0xffffffc00e000000 size 0x02000000 for rdp1
May  5 01:05:09 kernel: creating mapping for reserved memory phys 0x000000000b400000 virt 0xffffffc00b400000 size 0x02c00000 for rdp2
May  5 01:05:09 kernel: creating mapping for reserved memory phys 0x000000000a900000 virt 0xffffffc00a900000 size 0x00b00000 for dhd1
May  5 01:05:09 kernel: pmc_init:PMC using DQM mode
May  5 01:05:09 kernel: Successfully retrieved NVRAM data from dtb
May  5 01:05:09 kernel: cfe-v^A: 1.0.38-163.231
May  5 01:05:09 kernel: CPU1: Booted secondary processor
May  5 01:05:09 kernel: CPU2: Booted secondary processor
May  5 01:05:09 kernel: CPU3: Booted secondary processor
May  5 01:05:09 kernel: Broadcom Logger v0.1
May  5 01:05:09 kernel: skb_free_task created successfully with start budget 256
May  5 01:05:09 kernel: ^[[0;34mBLOG v3.0 Initialized^[[0m
May  5 01:05:09 kernel: BLOG Rule v1.0 Initialized
May  5 01:05:09 kernel: Broadcom IQoS v1.0 initialized
May  5 01:05:09 kernel: Broadcom GBPM v0.1 initialized
May  5 01:05:09 kernel: >>>>> For primary mtd partition rootfs, cferam/vmlinux.lz UBI volume, vmlinux fs mounted as UBIFS <<<<<
May  5 01:05:09 kernel: Secondary mtd partition rootfs_update detected as UBI for cferam/vmlinux source and UBIFS for vmlinux filesystem
May  5 01:05:09 kernel: setup_mtd_parts: misc indx 2 name misc3 nvram configured size 1
May  5 01:05:09 kernel: setup_mtd_parts: name misc3 configured size 0x00100000 offset 0xF600000
May  5 01:05:09 kernel: setup_mtd_parts: misc indx 1 name misc2 nvram configured size 47
May  5 01:05:09 kernel: setup_mtd_parts: name misc2 configured size 0x02f00000 offset 0xC700000
May  5 01:05:09 kernel: setup_mtd_parts: misc indx 0 name misc1 nvram configured size 8
May  5 01:05:09 kernel: setup_mtd_parts: name misc1 configured size 0x00800000 offset 0xBF00000
May  5 01:05:09 kernel: brcmboard registered
May  5 01:05:09 kernel: brcmboard: brcm_board_init entry
May  5 01:05:09 kernel: print_rst_status: Last RESET due to SW reset
May  5 01:05:09 kernel: Initialized Runner Multicast Layer
May  5 01:05:09 kernel: ^[[0;34m[NTC bitpool] idx_pool_init: 551:FHW[0]:Create Index Pool_Size = 16512^[[0m
May  5 01:05:09 kernel: Retrieve num_fhw_path=64
May  5 01:05:09 kernel: ^[[0;36;44mPathstats allocated 2048 bytes^[[0m
May  5 01:05:09 kernel: ^[[0;36;44mBroadcom Packet Flow Cache HW acceleration enabled.^[[0m
May  5 01:05:09 kernel: Enabled Runner binding to Flow Cache
May  5 01:05:09 kernel: Initialized Runner Protocol Layer (800)
May  5 01:05:09 kernel: Broadcom Runner Blog Driver Char Driver v0.1 Registered <309>
May  5 01:05:09 kernel: Lservices Loaded - NComm, Inc.
May  5 01:05:09 kernel: exLinuxETH Loaded - NComm, Inc.
May  5 01:05:09 kernel: PCIe HCD (impl1)^M
May  5 01:05:09 kernel:   bcm963xx-pcie: [0] DT node available: /pcie@80040000
May  5 01:05:09 kernel:   bcm963xx-pcie: found port [0] GEN2 Core Rev [3.04] with 2 Lanes^M
May  5 01:05:09 kernel: getrcal for res select 5, int 653, ext 647, ratio 126 ratio1 136, rcal 8
May  5 01:05:09 kernel:   bcm963xx-pcie: Core [2] setting resistor calibration value to 0x8
May  5 01:05:09 kernel:   bcm963xx-pcie: core [2] link is DOWN^M
May  5 01:05:09 kernel:   bcm963xx-pcie: core [2] powered down^M
May  5 01:05:09 kernel: dhd_runner_profile_init: profile = 3 1024/0512 2048/1024 1024/0512 0512/0512 0512/0512
May  5 01:05:09 kernel: ^[[0;33;40mRunner DHD PCIE: vendor<0x14e4> device<0xaaa4> bus<1> slot<0>^[[0m
May  5 01:05:09 kernel: Initial configuration
May  5 01:05:09 kernel: =================================
May  5 01:05:09 kernel:     rx_post_flow_ring_base_addr : ffffffc02e3d8000
May  5 01:05:09 kernel:     tx_post_flow_ring_base_addr : ffffffc00a8d8000
May  5 01:05:09 kernel:     rx_complete_flow_ring_base_addr : ffffffc02e3dc000
May  5 01:05:09 kernel:     tx_complete_flow_ring_base_addr : ffffffc02e3da000
May  5 01:05:09 kernel:     r2d_wr_arr_base_addr : ffffff80024b9000
May  5 01:05:09 kernel:     d2r_rd_arr_base_addr : ffffff80024b9802
May  5 01:05:09 kernel:     r2d_rd_arr_base_addr : ffffff80024ba000
May  5 01:05:09 kernel:     d2r_wr_arr_base_addr : ffffff80024b9c02
May  5 01:05:09 kernel:     tx_post_mgmt_arr_base_addr : ffffff80024ba800
May  5 01:05:09 kernel:     tx_post_mgmt_arr_base_phys_addr : 0x2e321800
May  5 01:05:09 kernel:     r2d_wr_arr_base_phys_addr : 0x2e320000
May  5 01:05:09 kernel:     d2r_rd_arr_base_phys_addr : 0x2e320802
May  5 01:05:09 kernel:     r2d_rd_arr_base_phys_addr : 0x2e321000
May  5 01:05:09 kernel:     d2r_wr_arr_base_phys_addr : 0x2e320c02
May  5 01:05:09 kernel:     Doorbell Post Wakeup register : phy_addr: 0xc0802160, virt_addr: ffffff80024b2160
May  5 01:05:09 kernel:     Doorbell Complete Wakeup register : phy_addr: 0xc0802164, virt_addr: ffffff80024b2164
May  5 01:05:09 kernel:     Doorbell ISR : ffffffbffcf553a0
May  5 01:05:09 kernel:     Doorbell CTX : ffffffc02e252400
May  5 01:05:09 kernel:     flow_ring_format : 1
May  5 01:05:09 kernel:     idma_active : 1
May  5 01:05:09 kernel: Backup queue configuration:
May  5 01:05:09 kernel: ========================================
May  5 01:05:09 kernel: Base virt address = ffffffc00df00000, physical address =  DF00000
May  5 01:05:09 kernel: Index stack virt address = ffffffc00dfe38c0, physical address =  DFE38C0
May  5 01:05:09 kernel: Backup queue entries: total = 58250  shared by all radios
May  5 01:05:09 kernel: Creating CPU ring for queue number 1 with 128 packets descriptor=0xffffffbffc303f08, size_of_entry 16
May  5 01:05:09 kernel: Done initializing Ring 1 Base=0xffffff80003e3000 End=0xffffff80003e3800 calculated entries= 128 RDD Base=3e012000K descriptor=0xffffffbffc303f08
May  5 01:05:09 kernel: ^[[0;33;40mRunner DHD Offload initialization complete^[[0m
May  5 01:05:09 kernel: CUR_ETHERADDR : 6
May  5 01:05:09 kernel: 7c 10 c9 b4 2e 4c
May  5 01:05:09 kernel: Dongle Host Driver, version 17.10.157.2809 (r801046)
May  5 01:05:09 kernel: Compiled in drivers/net/wireless/bcmdhd
May  5 01:05:09 kernel: wfd_registerdevice Successfully registered dev eth7 ifidx 0 wfd_idx 1
May  5 01:05:09 kernel: Register interface [eth7]  MAC: 7c:10:c9:b4:2e:4c
May  5 01:05:09 kernel: proc_dostring_crashlogsave:  crash log filename is /jffs/crashlog.log
May  5 01:05:09 kernel: crashFileSet: log signature invalid !
May  5 01:05:09 kernel: ret 0 retlen 65536 buff <6>ehci-platform ehci-platform.0: irq 28, io mem 0x8000c300
May  5 01:05:09 kernel: CSIMON:  CSIMON[1.1.0] Initialization
May  5 01:05:09 kernel: CSIMON: M2M usr already registered ...
May  5 01:05:09 kernel: Interface eth%d doesn't exist
May  5 01:05:09 kernel: could not find igs interface!
May  5 01:05:09 kernel: IGMP Query send failed
May  5 01:05:10 kernel: CSIMON:  CSIMON[1.1.0] Initialization
May  5 01:05:10 kernel: CSIMON: M2M usr already registered ...
May  5 01:05:11 kernel: CSIMON:  CSIMON[1.1.0] Initialization
May  5 01:05:11 kernel: CSIMON: M2M usr already registered ...
May  5 01:05:12 avahi-daemon[1599]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
May  5 01:05:12 Mastiff: init
May  5 01:05:12 wsdd2[1686]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
May  5 01:05:12 lldpd[1709]: cannot get ethtool link information with GLINKSETTINGS (requires 4.9+): Operation not permitted
May  5 01:05:13 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link Up at 1000 mbps full duplex
May  5 01:05:14 wsdd2[1686]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
May  5 01:05:15 wsdd2[1686]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
May  5 01:05:15 kernel: tfat: loading out-of-tree module taints kernel.
Feb 28 15:57:10 kernel: SHN Release Version: 2.0.1 21224-01
Feb 28 15:57:10 kernel: UDB Core Version: 0.2.20
Feb 28 15:57:10 kernel: Registered DNS Req parsing
Feb 28 15:57:10 kernel: sizeof forward pkt param = 280
Feb 28 15:57:11 kernel: wl0: random key value: 0253C6CC4BE5CBBA165800C1C9B9F31FD86EC0526B64067F38C8FC4BFBD3A63C
That's normal. May 5 is the default date the router starts up with. Once it has connection to the internet it updates the date and time with the correct values.
For 57 seconds, actually. The router rebooted.
Feb 28 15:56:13
Feb 28 15:57:10
