Selecting my Router for NAS
I have a QNAP TS-419P+ 4 bay with Seagate 7200 RPM Baracuda 2TB drives in a RAID 10 setup.
Gives me 3.89TB (2 drives) mirrored to 3.89TB (2 drives)
This has dual RJ45 1GB connections for either load balancing or fail over (which I have it that way)
eSata port on back for backup to external drives (which I use a Thermaltake BlacX for that when I want to)
USB ports on back and one in front the can be setup to auto copy USB flash stuck in, no user input needed
I also use it for TimeMachine backups from my iMac
but I keep it turned off most of the time and also my Dlink DNS-323 with mirrored 1TB drives (will get around to putting funplug on it maybe even thou the item is discontinued from Dlink it still has a big user support base and forums)
You can not get that with a DIY home NAS, which your really not building a NAS, your making a bare bone pc, and the power usage will be a lot.
When my QNAP is off (and wake on LAN disabled) the draw is about .2 of a WATT because the network connections are still active, on the Dlink it is zero, off means off.
My QNAP uses CLAMX antivirus program, that is FREE, on the last 2 firmware upgrades, so it can do full scans with the latest signatures. It can be a linux server, DHCP, DNS, AFP, active directory, radius, many many things and all that is included in the QNAP.
You can't do that with a DIY "NAS" because you will spend a lot of time trying to get different software to work.
I suggest AGAINST RAID5, go RAID 10 and use a NAS box already built. I used Baracuda Enterprise drives so I would never worry about a failure (it's more of a file storage device and not a full blown NAS with 20 users 10 hours a day, BUT the QNAP could be in a small business).
Use WD RED NAS hard drives and they just came out with 5TB and 6TB drives. So a 2 bay mirrored 6TB setup could be well suited for most home/SOHO users. And the QNAP has "cloud" access from mobile/net so you could setup your own "cloud", just limited by your UPLOAD speeds.
Just my input after reading this post. :)
