Hi, I don't have much experience with SOHO gear when it comes to NAS devices so I figured it would be good to ask for advice.
Family friend is looking for a new NAS for exactly 3 usage scenarios:
FTP connection from an MFC printer to dump faxes and scans into.
SMB file dump for sharing between 3 PCs. For the most part this is just excel, word and acrobat files.
Backups of the 3 computers.
Nice but not critical features:
Backups of the NAS to an external USB HDD connected to the NAS.
Hot Swap HDDs that where a failed drive can be replaced without unscrewing the case.
Raid volume expansion, starting off with 2x 1TB drives and going to 2x 4TB drives without wiping the data.
Speed is not the primary concern here. Simplicity and reliability is. If the manufacturer has a significantly longer than usual warranty(3+ years) (and the tech support is competent) that is a plus. If the manufacturer has a history of releasing buggy firmware updates, then that is a huge detraction.
Thank you!
Thank you!
