It looks like firefox isn't respecting your timezone in that case
I use https://momentjs.com/docs/#/parsing/unix-timestamp/ which should return for your timezone
a quick google suggests this forces firefox to utc, that would explain it!I have found the fix as well if anyone else interested,
setting this value to false fix the issue in about:config
privacy.resistFingerprinting=false
Thanks Jack Yaz for you time
use connmon
ookla servers dont all support latency testing - it would be a nightmare trying to support that
yes. with graphsso to just clear things for me up is this script to just get an speedtest on the router ?
NordVPN—US3038—Time—Download(Mbps)—Upload(Mbps)
NordVPN—US3038—Time—Download(Mbps)—Upload(Mbps)—Latency(ms)
click the legendGreat script, use it for quite some time now! However a while ago the GUI changed from a separate upload/download graph to a combined one and that doesn't work out well with synchrone connections... A have a basic 150/150 mbit fiber at home but the graph became close to unreadable. Separate graphs or a configuration to use separate or combined would greatly improve readability on synchrone connections.
Haha so easy...! Must admit I personally liked the separate graphs better but improves the readability a lot, thanks!click the legend
try temporarily deleting your config file in /jffs/addons/spdmerlin.d and reinstallingHello, after a problem with my USB key, I had to format a new one and redo a swap and Entware file. I have a problem with SPDMerlin which no longer works and when I try to reinstall it I have this message:
spdMerlin: Lock file found (age: 324 seconds) - stopping to prevent duplicate runs. ( log file)
With terminal :
thor @ RT-AX88U-8628: / tmp / home / root # / usr / sbin / curl --retry 3 "https: //raw.githubu
sercontent.com/jackyaz/spdMerlin/master/spdmerlin.sh "-o" / jffs / scripts / spdmerli
n "&& chmod 0755 / jffs / scripts / spdmerlin && / jffs / scripts / spdmerlin install
% Total% Received% Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 63428 100 63428 0 0 201k 0 -: -: - -: -: - -: -: - 210k
spdMerlin: Stale lock file found (> 600 seconds old) - purging lock
spdMerlin: Welcome to spdMerlin v3.6.1, a script by JackYaz
spdMerlin: Checking your router meets the requirements for spdMerlin
spdMerlin: Installing required packages from Entware
Downloading http://bin.entware.net/aarch64-k3.10/Packages.gz
Updated list of available packages in / opt / var / opkg-lists / entware
Package sqlite3-cli (3320100-1) installed in root is up to date.
Package jq (1.6-1) installed in root is up to date.
Package p7zip (16.02-3) installed in root is up to date.
/ jffs / scripts / spdmerlin: line 2033: can't create /opt/share/spdmerlin.d/.interfaces: nonexistent directory
touch: /opt/share/spdmerlin.d/.interfaces_user: No such file or directory
/ jffs / scripts / spdmerlin: line 2033: can't open /opt/share/spdmerlin.d/.interfaces: no such file
/ jffs / scripts / spdmerlin: line 2033: can't open /opt/share/spdmerlin.d/.interfaces_user: no such file
[: bad number
sed: /opt/share/spdmerlin.d/.interfaces_user: No such file or directory
[: bad number
[: bad number
[: bad number
[: bad number
[: bad number
[: bad number
What should I do ? Thank you !
I also had this message but not after a reinstall. It basically means there is a lockfile in a temp folder that prevents spdmerlin from running because this file should only exists when the script is performing a speedtest. Which firmware are you using? For me a hard reboot solved this. A reboot from the GUI wasn't actually rebooting the system according the the boottime info.
It also looks like the the entware or spdmerlin install was not correct since the router can't find a directory in which some script files should be located.
Just delete the lock file in the temp folder.hi, i'm under the latest merlin version: 384_18. it is true that I did not restart the router with the physical button but only via the GUI. I'm going to try. thank you
Location you will find in script file at the very beginning, if I remember correctly.
Sent from my OnePlus 7 Pro using Asus RT-AC86U & Merlin 384.17
Thread starter | Title | Forum | Replies | Date |
K | spdMerlin Problems installing spdMerlin on Asus RT-AX86U_Pro | Asuswrt-Merlin AddOns | 8 | |
D | Skynet, speedtests, CGNAT | Asuswrt-Merlin AddOns | 3 |
Welcome To SNBForums
