Hello everybody,
I'm planning to buy a NAS for several weeks now, and the more research I'm doing the more I am convinced that these NAS things just kill you - by desperate starvation while you're trying to work out what to buy!
Maybe some of you experienced users could give me some advice...
Everything started (and is connected) with my other plan of replacing my current 17" notebook by a new subnotebook with an SSD and a docking station. As SSDs are still quite expensive and shouldn't be packed to 100% with data, I would like to move all seldom used data to a NAS (what makes the data still accessible by LAN, WAN or the Internet) and could also replace the six USB disks which are currently floating around (80gig to 1TB in capacity). These disks are also used for recordings with a HD SAT receiver, but it's getting really hard to remember what data is currently gone where. So the plan is to get a 3/4/5-bay NAS to get things back in order. Besides SMB/CIFS it should provide GBit LAN and secure SFTP and/or HTTPS access from outside my home - that's all I initially thought of and that's also where the crisis of my last three weeks started...
Normally, a 3TB RAID5 (3x 1.5TB) should be sufficient to store my data. That should give me about 1TB for important data (which can be backed up to the 1TB USB drive) and 2TB for other stuff like TV recordings, DVD images and so on.
Frustrated, I spent the next few evenings on working out alternative plans. Building a FreeNAS box, for example. But actually there are not many cases around, which are really suitable to build a NAS, and the usual Chenbro case is quite expensive as well. I could use any bargain mini tower case and stuff in a 4-drives-hot-swap frame, but I don't like the idea of the case being so big. Next thing was to find an Atom motherboard with GBit ethernet, at least 4 SATA connectors and an expansion slot for a second GBit NIC. There are few, to be honest. Then I didn't like the FreeNAS RAID not being dynamically expanable, and I also know it'll be hard to find the time, nerves and energy to install and optimise my own Linux installation. I better buried that branch.
As another compromise, I found the Thecus N4200, which comes as a 4-bay hot swap, 2GBit eths, Atom-powered, 1GB RAM, Wake-On-LAN NAS with an USV already included, while the price of 520EU is only a little bit higher than QNAP's 419P. But still, I somehow like the QNAP or Synology software package much more than Thecus' - they simply "feel" to be superior or a little bit more polished (the same can be said for their documentation as well). And according to the latest c't review (which is a quite famous German PC magazine) the N4200 also shares the drives-not-powering-down bug with it's smaller cousin (N0503)... but then again, the N4200 is such a deal for it's money?!?
So this is where I am now: repeating the above steps over and over again!
Well, if I try to get all my NAS thoughts in order (what is getting harder and harder every day!), then I seem to have only four valid options:
Thank you very much, guys! And sorry for the lengthyness of my gush and the rusty English (I'm Bavarian after all, which is near Germany), but I tried hard to describe my dilemma as good as possible...
Best regards, Alex_G
- So I first took a look at the Synology DS-409 for around 350EU. I like the price and the software, and performance is not too bad either. But the longer I looked, the more I disliked the idea of lacking hot-swap drive trays, and also a second GBit connection (1x for the NB's docking station, 1x for the WAN router) would be quite nice as it would free me from buying an additional (and permanently running) GBit switch. Also the 256MB RAM look a bit small nowadays, since I started thinking of creating and hosting a small website or blog for our choir while reading though the feature list...
- So the QNAP TS-410 for around 360EU seemed like the next logical choice, as it features hot-swap drive trays and the second GBit connection. Unfortunately, performance-wise it's rather a small step in the wrong direction with it's Marvell 800MHz CPU?!?
- That's when I found the Thecus N0503 for around the same amount of money (350EU). It's Atom powered, it provides 1GB of RAM, and you can easily swap hard drives. But being 3-bay only, it has the disadvantage that I can't add another disk later-on. So to be on the safe side, I'd rather opt to start off with 2TB drives with the N0503? But that eats up the price advantage to quite a degree, and I also didn't like the press reviews and the software features as much as with Synology or QNAP. According to reviews the fan is louder as well, and there seems to be a problem with drives not powering down on idle. So I kept on looking around...
- What else is available? The Synology DS-409+ for around 440EU is still missing hot-swap drive bays and the second GBit connector, though I liked it feature-wise apart from that.
- The QNAP TS-419P for ~480EU has both, and also quite a low standby power consumption. However, while checking the specifications and reviews, I saw that not all extension packages are available for the ARM based QNAP NASes, and I also thought the missing Wake-On-LAN feature might be actually quite useful (even more than low power usage)?!? Additionally, my new notebook with it's SSD might be quite fast, so it would be nice if the NAS would be quite fast as well?!?
- So I had a look at QNAPs Atom models, the TS-439 Pro for about 650EU and the TS-439 Pro II for around 700EU. I think both of these models are "NAS heaven" regarding their performance and feature set (even including IPv6 for the future), and with the price difference being that low, I'd rather opt for the newer model (Pro II) due to the idle power consumption being 10watts lower.
- Get the Synology DS409 and, whenever I regret it, becalm myself with the idea of having saved lots of money
- Get the QNAP-419P as a good energy-saving compromise (I guess it does most of what I'll ever need)
- Get myself drunk and then happily order the QNAP TS-439 Pro II with Wake-On-LAN and all it's geeky "Uber" feature stuff
- Get the Thecus N4200 and give it a thorough try though I don't "like" it as much up-front?
