vnStat [Solved] vnstat issue
Milan
Idetected that the vnstat stopped updating data so I checked the settings and it was using jffs to store data. So i tried to change the place of storage but i am getting this error always:
chmod: /jffs/scripts/dn-vnstat: No space left on device
when uninstalling then :
rm: can't remove '/jffs/addons/dn-vnstat.d/vnstat-ui.asp': No space left on device
No packages removed.
rm: can't remove '/jffs/addons/dn-vnstat.d/.vnstatusage': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/images/vnstat_m.png': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/images/.vnstat_s.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/images/.vnstat_d.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/images/vnstat_hg.png': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/images/.vnstat_t.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/images/vnstat_s.png': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/images/vnstat_d.png': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/images/.vnstat_hg.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/images/vnstat_t.png': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/images/.vnstat_m.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/images': Directory not empty
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/DataUsage_day_monthly.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/DataUsage_fiveminute_monthly.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/DataUsage_hour_monthly.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/DataUsage_fiveminute_weekly.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/DataUsage_hour_daily.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/WeekSummary.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/dn-vnstatdata.zip': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/DataUsage_fiveminute_daily.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/DataUsage_day_weekly.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/DataUsage_hour_weekly.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/WeekPrev.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/WeekThis.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv/DataUsage_day_daily.htm': No space left on device
rm: can't remove '/jffs/addons/dn-vnstat.d/csv': Directory not empty
sed: can't create temp file '/jffs/addons/custom_settings.txtFG5vNB': No space left on device
sed: can't create temp file '/jffs/addons/custom_settings.txtooanMA': No space left on device
Jffs is not full by firmware:
How to solve this? it is happenning only for this one script ...
Reboot the router. If it still isn't working post the output of the following command:
mount | grep jffs
mount | grep jffs
Reboot helped. Will see if the data is updated ...
EDIT: all is working fine.
