Vpn fusion not able to have 2 OpenVPN configs active.
madifor
I have a gt-ac5300 where you can create multiple vpn tunnels under VPN-Fusion
Created 2 OpenVPN configurations which have 2 different lan-subnets behind it.
I am able to reach the network behind Tunnel 1 the traffic is routed correctly , but when i try to do a traceroute to the network behind Tunnel 2 it doesnt work.
However when i make the Tunnel 2 as default ... it is the other way around
Is this something that can be resolved or is this a bug / limitation of the Fusion configuration for my wifi router??
