Web proxy running locally on ASUS Router
egrigolon
Hello.
First of all, my knowledge about networks and routers is minimal. Perhaps the thread title isn't correct.
Let me try to explain what I need/want to do.
My company recently started blocking URL access using Windows Defender.
No matter where I am, access to those websites is blocked at the OS level.
I want to be able to navigate freely while at home.
Of course, there are tons of online web proxies out there that can hide the URL.
But I don't want to run into the issue of my favorite web proxy being blocked as well.
So, I thought that perhaps there's a solution where I can run my web proxy locally.
In other words, I want to access (example) https://10.0.0.2:xxxx/ and type the URL I want to access behind the proxy so I can navigate without being blocked.
Something like https://www.startpage.com/ or whatever.
Is there something like that out of the box? Or that requires a bit of step-by-step to make it work?
Or perhaps a clever solution that I'm not aware of?
Please explain to me if I were 8 years old (which I'm not, most of the time).
Thank you!!
Edit: I have an RT-AX88U router running asusmerlin and I have access to amtm and stuff.
If you're asking how to bypass a company-issued device, don't.
Use your personal computer for such. And configure it as you see fit.
Yeah, as well-liked as an employee may otherwise be, bypassing company security measures on a company computer (even at home and for personal use) may well earn a pink slip. Not worth it.
