Solved Cannot upload self-signed cert for web UI
unsynaps
I have been trying to upload a self-signed cert to the web UI and it seems to refuse to be accepted. Best I can tell it worked fine in the past.
Logs are throwing the following:
Mar 19 23:46:35 httpd: Can't get subject/authority key identifier. ([F6:2C:1C:3]/[NULL])
Mar 19 23:46:35 httpd: Delete uploaded certificate
No other errors are given.
Certs generated in XCA.
Uh... OK?
Really tired of this mentality of people thinking they are helping just posting a link with zero explanation. Especially when the link offers no sensible solution to the problem.
Uh... OK?
OK Given that exactly the same error was reported in that thread I thought Merlin's response might have been of some help. Next time I won't bother trying to help.
After some sleep and coffee, I found the answer.
Please post "the answer" for others who may have the same issue and read your thread.
I am experiencing a new error uploading my own certs. They worked fine for years, and the latest update the router switched to "Auto" and generated a new cert.
I see nothing in the system logs. What would be the best way to diagnose this?
I am using mkcert (https://github.com/FiloSottile/mkcert) which has worked great in the past.
Actually I found the issue.
b_constr = x509v3ext2str_by_nid(x509_cert, NID_basic_constraints);
if (!b_constr) {
_dprintf("%s: Can't get basic constrain from %s\n", __func__, cert_fn);
logmessage("httpd", "Can't get basic constrain from %s", cert_fn);
ret = -7;
goto err_set_uploaded_cert_as_cacert;
When I logged all, it finally showed up. Is this absolutely required? The mkcert generated certs worked fine, and now they no longer function. =(
I also started a discussion on the mkcert github. https://github.com/FiloSottile/mkcert/discussions/583
