I have strange connections problems with my new AC-87U (latest merlin build, as well with stock firmware).
Devices loses connections to the 5GHz Wifi all the time and do not reconnect until I do it manually. Often the devices switches from the 5GHz SSID to the 2.4GHz.
With iPhone, iPad, MacBook Pro and a HP Laptop - all the same.
Often, when connected to the 5GHz Wifi, the speed is very very bad, sites do not load proper.
When I check wireless stats:
SSID: "router5"
RSSI: 0 dBm SNR: 22 dB noise: -47 dBm Channel: 40/80
BSSID: 54:A0:50:E5:84:5C Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
as you can see I see SNR: 22 db while with the 2.4GHz moddule I have a constant SNR of 0 db. As I know SNR means signal noise radio and this is bad.
Even when I manually set up different channels for the 5GHz module this SNR reminds.
Could this be a hardware problem? Should I make an RMA request?
SSID: "router5"
