Not sure if it is a bug, or works as designed.
Situation:
Asus AC66u with RMerlin 3.0.0.4.374.34 installed
2.4 GHz settings:
wireless mode auto
WPA2-Personal
AES
Check optimized Xbox and b/g protection
channel bandwith 20/40Mhz
With these settings it seems that setting a specific channel does not work at all: every single choice of the array [1l,2l,3l,4l,5l,5u,6l,6u,7l,7u,8l,8u,9l,9u,10u,11u,12u,13u] outputs to wlan channel 6
Tested this with dd-wrt build 22118 and inSSIDer.
To make it even more strange, I was able once, and only once, to get the WLAN channel according to my setting of 11u. But every next attempt te reproduce this, kept bringen channel 6 back alive.
I am investigating this issue because I have great trouble to have dd-wrt and/or tomatousb as wireless clients to connect to the asus. Right now i am not sure where the issues are. But I do know that connecting the same hardware/software combination to for example an Apple Airport Express seems to work OK. Only switch SSID settings and no luck at all. (At my home all WPA2 keys are set with the same personal passphrase).
So I don't know is the above described behaviour is a bug, or works as designed with the auto channel with settings on. In the latter case I think it should be impossible to set user channels.
Tnx all
Situation:
2.4 GHz settings:
wireless mode auto
WPA2-Personal
AES
Tnx all
