Wireless throughput Netgear WNR854T vs WNDR4500
Susurs
Hi!
I want to upgrade from my old Netgear router (WNR854T) and decided that I'd like to get WNDR4500...
However when I look at the benchmark figures of wireless throughput there I see that WNR854T performs slightly better (???) than WNDR4500... Do I understand the figures correctly? Can it really be that the WNR854T has better wireless throughput?
http://www.smallnetbuilder.com/myin...ear_wndr4500_retest_2-4ghz_2strm_40mhz_dn.jpg
http://www.smallnetbuilder.com/imag...ear_wndr4500_retest_2-4ghz_2strm_20mhz_dn.jpg
http://www.smallnetbuilder.com/imag...ar_wnr854t_wireless_max_throughput_dn_big.png
The two measurements were taken with completely different computers and wireless client cards. You can't really directly compare the performance of the two products.
Thanks for reply!
Is there any information on how much WPA2/AES
decreases wireless throughput compared to no security mode?
That issue was solved a long time ago. Current 802.11n products have no significant difference in throughput between no encryption and WPA2/AES.
Using WEP or WPA/TKIP will limit link rates to 54 Mbps and below and throughput to 802.11g speeds (22 Mbps maximum / 10 Mbps typical with moderate strength signal).
