I think this is a bug in stock firmware and even merlin. I installed now DD-WRT again and this works.
As you can see in logs, client (eg. 192.168.2.51 - smartphone) will not be registered in network. Router acceppts no more incomming requests at 2,4GHz network after some minutes.
DHCP-Nutzungen:
Hostname IP Address MAC Address Expires
DELL 192.168.2.2 e8:2a:ea:90:f5:42 23:59:01 DELL Precision M3800
Michaels-iPad 192.168.2.37 40:30:04:24:31:62 23:58:38 iPad2
OPWL20001E3687446 192.168.2.4 00:01:e3:68:74:46 23:58:29 VoIP-DECT
android-b4403e2f96d35731 192.168.2.51 90:18:7c:d2:6a:85 23:58:11 Galaxy S3 mit Stock-Firmware
Verbindungen:
Android: - WLAN aus -
Proto NATed Address Destination Address State
tcp 192.168.2.37:61895 17.130.254.34:5223 ESTABLISHED
tcp 192.168.2.37:61896 193.149.80.67:443 ESTABLISHED
udp 192.168.2.4:5060 217.10.79.9:5060 ASSURED
udp 192.168.2.2:51944 192.168.1.16:161 UNREPLIED
udp 192.168.2.2:51944 192.168.1.10:161 UNREPLIED
Android: - WLAN ein -
tcp 192.168.2.2:65119 173.194.39.1:443 ESTABLISHED
tcp 192.168.2.37:61903 213.199.179.157:40033 ESTABLISHED
tcp 192.168.2.2:65120 173.194.39.5:443 ESTABLISHED
tcp 192.168.2.37:61904 91.190.216.81:80 TIME_WAIT
Android: - IP wird abgerufen -
Android: - Verbinden -
Android: - Verbindung mit 5G -
tcp 192.168.2.51:56647 173.194.65.188:5228 CLOSE
tcp 192.168.2.51:40565 173.194.65.188:443 ESTABLISHED
tcp 192.168.2.51:41406 54.195.251.62:5223 ESTABLISHED
tcp 192.168.2.51:34734 31.13.100.11:443 ESTABLISHED
tcp 192.168.2.51:39717 173.194.39.6:443 ESTABLISHED
tcp 192.168.2.51:49200 31.13.100.11:443 ESTABLISHED
tcp 192.168.2.51:53714 31.13.93.5:443 ESTABLISHED
tcp 192.168.2.51:54578 173.194.39.6:80 ESTABLISHED
tcp 192.168.2.51:40730 173.194.39.6:80 ESTABLISHED
tcp 192.168.2.51:38293 173.194.39.1:80 TIME_WAIT
tcp 192.168.2.51:38382 173.194.39.6:443 TIME_WAIT
Wireless-Protokoll:
SSID: "Michl24"
RSSI: 0 dBm SNR: 0 dB noise: -92 dBm Channel: 1
BSSID: 38:2C:4A:4B8:F0 Capability: ESS ShortSlot
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
VHT Capable:
Chanspec: 2.4GHz channel 1 20MHz (0x1001)
Primary channel: 1
HT Capabilities:
Supported MCS : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
22 23 ]
VHT Capabilities:
Supported VHT (tx) Rates:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Supported VHT (rx) Rates:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Mode : AP Only
Stations List
MAC Associated Authorized RSSI PSM SGI STBC Tx rate Rx rate Connect
Time
00:01:E3:68:74:46 Yes Yes -32dBm Yes No No 1M 54M 00:21:11
SSID: "Michl5"
RSSI: 0 dBm SNR: 0 dB noise: -92 dBm Channel: 36/80
BSSID: 38:2C:4A:4B8:F4 Capability: ESS
Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
VHT Capable:
Chanspec: 5GHz channel 42 80MHz (0xe02a)
Primary channel: 36
HT Capabilities:
22 23 ]
VHT Capabilities:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Mode : AP Only
Stations List
Time
90:18:7C2:6A:85 Yes Yes -45dBm No Yes No 108M 150M 00:02:27
E8:2A:EA:90:F5:42 Yes Yes -52dBm No Yes Yes 526.5M 866.7M 00:20:42
40:30:04:24:31:62 Yes Yes -62dBm Yes No No 65M 65M 00:21:01
But I'm annoyed about the ASUS support. There only people who question catalog/basic questions. Typical first level support.
I have suggested that a technician or programmer looks at the problem in a remote maintenance, but apparently there is no third level support at ASUS.
Perhaps Merlin is more interessted to improve Merlin firmware.
DHCP-Nutzungen:
Verbindungen:
Wireless-Protokoll:
SSID: "Michl24"
VHT Capable:
Primary channel: 1
HT Capabilities:
22 23 ]
VHT Capabilities:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Mode : AP Only
Stations List
Time
SSID: "Michl5"
VHT Capable:
Primary channel: 36
HT Capabilities:
22 23 ]
VHT Capabilities:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Mode : AP Only
Stations List
Time
