2.5 GbE Switch for AX88U Pro
dylanmitchell
What are the best 2.5 GbE Switches for AX88U Pro? Two 2.5Gbps Multi-Gig ports suggest the use of a switch to get beyond the limitation of four 1Gbps ports but I've never seen an Asus switch. There are plenty of switches from other companies but an Asus switch with 2.5 Gpps to swith and four 1Gbps ports or 2.5 Gbps ports and POE+ would be expand Asus router capability. Someting that fits with Asus and is more capable then a GS105 and priced under USW-Enterprise-8-PoE.
Any switch you want will work, even no-name brand. Most have the same hardware inside anyway.
