2 VPN Client and 2 WiFi SSID: how to route traffic
As described in post #98 ; you can continue to use nat-start or (preferably) use the openvpn-event vpnclient-route-up script to call WiFiVPN.sh
/jffs/scripts/vpnclient-route-up
/jffs/scripts/WiFiVPN.sh $WIFI_IF $VPN_ID &                    # Bridge X via this VPN
or in the worst case scenario use the openvpn-event vpnclient-up script to run a background VPN Syslog Monitor script to call WiFiVPN.sh when the appropriate 'successful reconnect' message appears
/jffs/scripts/vpnclient-up
/jffs/scripts/VPN_SyslogMonitor.sh $VPN_ID &
hey thanks for the prompt reply. I was already using the nat-start option but it wasnt working for my scenario. However the vpnclient-route-up scripts seems to be working. I will continue testing this and report back if any errors occur.
thanks a lot !
My goal is when I'm using specific lan port, then the I'm routed to the VPN client assigned to the bridge.
Someone has succeffully added local ports to bridges created with wifivpn?
I would like to;
1- add LAN port 3 (id 2 from AC56U) assign on bridge 1
1- add LAN port 4 (id 3 from AC56U) assign on bridge 2
I Have created the vlan 3 an 4 and assigned the LAN ports correclty. And Assigned thoses vlans to the bridges. But no IP address is assign to my lan card interface when's connected. Any idea?
I would like to;
see post #68 ?
I'm using your script WIFIVPN.sh for accessing VPN client configuration. But I would like to configure specific LAN ports to do the same. I've created correctly the vlan (3 and 4 in my case). Also assigned those to the previously created bridges (br1 or br2 depending of the vlan and the lan port mapped).
See;
ME@MyRouter_share:/jffs/scripts# brctl show
bridge name    bridge id        STP enabled    interfaces
br0        8000.305a3aa05088    yes        vlan1
                            eth1
                            eth2
                            wl0.2
                            wl0.3
                            wl1.1
                            wl1.3
br1        8000.305a3aa05089    no        wl0.1
                            vlan3
br2        8000.305a3aa0508e    no        wl1.2
                            vlan4
MyRouter_share:/jffs/scripts# vconfig show
BusyBox v1.25.1 (2018-03-24 13:01:24 EDT) multi-call binary.
Usage: vconfig COMMAND [OPTIONS]
Create and remove virtual ethernet devices
add IFACE VLAN_ID
rem VLAN_NAME
set_flag IFACE 0|1 VLAN_QOS
set_egress_map VLAN_NAME SKB_PRIO VLAN_QOS
set_ingress_map VLAN_NAME SKB_PRIO VLAN_QOS
set_name_type NAME_TYPE
ME@MyRouter_share:/jffs/scripts# robocfg show
Switch: enabled
Port 0:   DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 1:   DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 2:   DOWN enabled stp: none vlan: 3 jumbo: off mac: 00:00:00:00:00:00
Port 3: 1000FD enabled stp: none vlan: 4 jumbo: off mac: b8:a3:86:78:b5:0b
Port 4: 1000FD enabled stp: none vlan: 2 jumbo: off mac: b8:ec:a3:35:11:b6
Port 5: 1000FD enabled stp: none vlan: 2 jumbo: off mac: 30:5a:3a:a0:50:88
Port 7:   DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 8:   DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
VLANs: BCM5301x enabled mac_check mac_hash
   1: vlan1: 0 1 5t
   2: vlan2: 4 5
   3: vlan3: 2 5t
   4: vlan4: 3 5t
  56: vlan56: 0 3 4 5t 7t 8u
  57: vlan57: 0t 1t 5t 7t 8u
  58: vlan58: 2t
  59: vlan59: 0t 2t 4t 8u
  60: vlan60: 0t 5 7 8t
  61: vlan61: 1t 2 3 4t 5t
  62: vlan62: 2t 4t 5t
But the DHCP don't assign any IP to my lan interface. Any idea?
I would strongly recommend that you refrain from using single digit VLANs (e.g. vlan3 etc.) as they are nominally reserved by Asus.
I prefer to have the VLANs defined in 'dnsmasq.conf', simply because VLANSWitch.sh is then able to reference the dnsmasq entries consistently when it creates the designated VLAN and subsequently adds it to the appropriate VPN bridge created by WiFiVPN.sh.
Have you tried assigning the VLAN its I/P address and subnet mask manually?
ifconfig $VLAN $VLAN_IP netmask $VLAN_MASK up
Martineau, Thanks for your advise and your help, again!
Can I use the same ip address range than the associated WIFI ID . Could you tell me how should I configure the dnsmasq.conf. Is it with WiFiVPN script or from CLI with vi?
No! I did not set any IP. vlan1 doesn't have one, why others vlan created should have one?
Here's the script I'll use for auto start all connexions at boot. Any suggestion?
# force local LAN port 3 to br1 for RT-AC56U
# force local LAN port 4 to br2 for RT-AC56U
robocfg vlan 1 ports "0 1 5t"
robocfg vlan 13 ports "2 5t"
robocfg vlan 14 ports "3 5t"
vconfig add wl0.1 13
vconfig add wl1.2 14
ifconfig vlan13 up
ifconfig vlan14 up
#add vlans to the bridges
brctl addif br1 vlan13
brctl addif br2 vlan14
#Not require
#ebtables -t broute -I BROUTING -p IPv4 -i vlan10 --ip-dst 192.168.1.0/24 --ip-proto tcp -j DROP
#ebtables -t filter -I FORWARD -i vlan10 -o ! eth0 -j DROP
#ebtables -t filter -I FORWARD -i ! eth0 -o vlan10 -j DROP
#Antenna 2.4Ghz, GuestWIFI 1, VPN1
/jffs/scripts/wifivpn.sh wl0.1 1
#Antenna 5Ghz, GuestWIFI 1, VPN1
#/jffs/scripts/wifivpn.sh wl1.1 1
#Antenna 2.4Ghz, GuestWIFI2, VPN2
#/jffs/scripts/wifivpn.sh wl0.2 2
#Antenna 5Ghz, GuestWIFI2, VPN2
/jffs/scripts/wifivpn.sh wl1.2 2
#Antenna 2.4Ghz, GuestWIFI3, VPN3
#/jffs/scripts/wifivpn.sh wl0.3 3
#Antenna 5Ghz, GuestWIFI3, VPN3
#/jffs/scripts/wifivpn.sh wl1.3 3
Also!!! here's the config that let me think that I don't need IP address on my new vlans.
eth1
eth2
wl0.2
wl0.3
wl1.1
wl1.3
vlan13
vlan14
ME@MyRouter_share:/jffs/scripts# ifconfig vlan1
vlan1     Link encap:Ethernet  HWaddr 30:5A:3A:A0:50:88
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:1 errors:0 dropped:0 overruns:0 frame:0
          TX packets:971 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:332 (332.0 B)  TX bytes:183995 (179.6 KiB)
ME@MyRouter_share:/jffs/scripts# ifconfig br0
br0       Link encap:Ethernet  HWaddr 30:5A:3A:A0:50:88
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          RX packets:9938 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8225 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1292102 (1.2 MiB)  TX bytes:3465089 (3.3 MiB)
ME@MyRouter_share:/jffs/scripts# ifconfig br1
br1       Link encap:Ethernet  HWaddr 30:5A:3A:A0:50:89
          inet addr:192.168.101.1  Bcast:192.168.101.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:23 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:3235 (3.1 KiB)
ME@MyRouter_share:/jffs/scripts# ifconfig br2
br2       Link encap:Ethernet  HWaddr 30:5A:3A:A0:50:8E
          inet addr:192.168.102.1  Bcast:192.168.102.255  Mask:255.255.255.0
          RX packets:130 errors:0 dropped:0 overruns:0 frame:0
          TX packets:128 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:35597 (34.7 KiB)  TX bytes:40025 (39.0 KiB)
As per post #68, when using my VLANSwitch.sh script it helps to identify/isolate issues since the WiFI SSID has a separate subnet then so does the VLAN for the bridge.
ifconfig vlan13 up
ifconfig vlan14 up
Did you manually configure the VLANs as per post #69 correctly? - as you appear to 'add' the VLANs to the Guest WiFi interface rather than the WAN interface?o_O
Could you send me your VLANSwitch.sh script? I do not have that one. Yes I configured the new vlan to use wifi interface. I will retry with eth0, witch is the wan interface. But I want to be sure that will let me use only 2 lan ports for my need. The other ports have to stay with the default configuration and routing (using vlan1 with br0).
I'll let you know my next step to test with eth0. Again, Thank a lot for your help!
Steph
No difference. Not working with eth0.
I"ve modified my script and rebooted the router. Still no IP address with lan port where I configured vlan 13 and 14. But get IP on other ports. My understanding is that the IP subnet used should be the one assigned to the bridge. Any idea?
ME@MyRouter_share:/jffs/scripts# vi nat-start
#!/bin/sh
vconfig add eth0 13
vconfig add eth0 14
ifconfig vlan13 up
ifconfig vlan14 up
[/CODE]
The ultimate goal is to;
-connect through the VPNclient1 connexion when I use interfaces (WIFI_2.4ghz_1, WIFI_5.0ghz_1 and lan_port1)
-connect through the VPNclient2 connexion when I use interfaces (WIFI_2.4ghz_2, WIFI_5.0ghz_2 and lan_port2)
-connect through the VPNclient3 connexion when I use interfaces (WIFI_2.4ghz_3, WIFI_5.0ghz_3 and lan_port3)
The VLANSWitch.sh script is currently used to allow the following
1 x Netgear GS108PEv3
1 x Netgear GS108Ev3
1 x Netgear GS108Ev2
3 x TP-link TL-SG2008
VLAN capable switches to isolate IoT devices and VPN access throughout the home.
NOTE: All hanging off Port 4 of the RT-AC68U in a predominately star topology with the GS108PE as the centre 'hub' in the loft (aka attic).
I doubt you personally would find it useful given your already advanced VLAN environment.
AP VLANs and pfSense
See PM ... I guess it can't hurt. ;)
e.g. Create VLAN20 on switch Port 3 and use VPN Client 1
./VLANSwitch.sh    20   3   vpn1   autodnsmasq   vlanfw
NOTE: Do you have CTF enabled? as this can unfortunately interfere with some setups.
Hi @Martineau
I have a RT-AC3200 I'm about to update to f/w asuswrt-merlin 384.5 and as such will be factory resetting.
So now would be a great time for me to use your script if possible to setup my VPN WiFi!
Any chance I could get a link? Thanks!
Hi @Martineau
It is in the thread..Post #7
Many thanks for your prompt response!
I ran the script and it did wonders (although it gave me few errors - like client1.resolv, client2.resolv file doesn’t exist, entry for iptable/ebtables, etc. - not sure why) - BUT it WORKS!!
My requirement actually is quite simple. I can manually assign ip address range in VPN client setup by setting policy rules e.g. VPN1 for 192.168.101.1/24. VPN2 for ...102.. etc.
What I need is a simple script that creates the respective bridge and ip range assignments (and can be run automatically after router restarts):
That is creating appropriate bridge/mapping required to assiciate wl01.1 to 192.168.101.1/24
wl01.2 to 192.168.102.1/24
Which I believe can be achieved by running a small part of your script.
Any help is greatly appreciated!!
Here’s the exact output:
(WiFiVPN.sh): 3360 v1.03b (Public Beta) © 2016-2017 Martineau, Guest WiFi VPN Br idge request.....[WL1 1]
**Warning for multiple ACTIVE concurrent VPN Clients UNIQUE ports are advised - Port 1195:UDP is configured for use by several VPN Clients
awkNR: /etc/openvpn/dns/client1.resolv: No such file or directory
iptables: No chain/target/match by that name.
(WiFiVPN.sh): 3360 WiFi (wl0.1) 2.4GHz Guest 1 WL1 (192.168.101.0/24) ro uted through tunnel VPN Client 1 (XVPN1) using WAN DNS (xxx.xx.xx.x) via b ridge:br1
Hi, I'm trying to use the script on an RT-AC86U and when I enter the following command I get the error.
@RT-AC86U-9370:/jffs/scripts# ./wifivpn.sh eth1 1
./wifivpn.sh: line 1002: /usr/sbin/brctl: not found
(wifivpn.sh): 16490 v1.03b (Public Beta) © 2016-2017 Martineau, WiFi VPN Bridge request.....[eth1 1]
./wifivpn.sh: line 1115: /usr/sbin/brctl: not found
(wifivpn.sh): 16490 ***ERROR WiFi (eth1) 2.4GHz Network WiFi 'eth1' not ENABLED. ABORTing.....
Any idea what i'm doing wrong or am I too lost to help? I'm new at this. Thanks in advance for any help.
Not sure if the absolute path to the brctl utility is different on the RT-AC86U ? you could check by issuing:
which brctl
but the location is moot as sadly the RT-AC86U isn't compatible with the script see post #31
