helminiak247
I ended up with modem in "pass-through" mode
* Asus GT-AX6000 (Two 2.5G ports) Wall mounted with everything "inside" wall
* TRENDnet 8-Port Unmanaged 2.5G Switch, the only one I could find that had a high speed 40Gbps Switching
* Sabrent USB 2.5 Gigabit Ethernet Adapter for 2 laptops
Not ideal but best for the time being (I'm using AiProtection in the router and SentinelOne core) That "should" cover me
Any cheap testers for running the CTA6a cable? I'm going to do a patch panel just because I can make it "look" neat/clean. Other end is just going to be keystone jacks. Just want to ensure the cables are supporting at least 10G speeds.
