3.0.0.4.374.40_alpha4 AC68U
ncyclon
Hi, I installed last alpha in hope, that in dual wan fixed problem with "WAN(0) Connection: ISP's DHCP did not function properly" (DHCP was in normal mode, now this option disappeared) but problem is still present.
In this alpha disappeared fallback option in dual wan, and still doesn't work traffic monitor.
Thanks.
Thanks.
I believe some of the dual wan issues have been fixed in recent versions, upgrade to the latest version and do an nvram reset.
https://github.com/RMerl/asuswrt-merlin/archive/374.43_2.zip
There should also be a new release from merlin in the coming weeks based on the 1779 GPL.
do an nvram reset.
If after nvram reset I will load backup of config, this will not remove "nvram reset" effect? Or I need to input all settings again?\
Also in asuswrt-merlin-374.43_2 I can't change setting of wan interfaces in Dual Wan mode.
Its best you manually reconfigure to avoid issues, most settings don't need to be changed so it shouldn't take long.
But what about setting of wan interfaces in Dual Wan mode? I can't change it ) On this alpha I have no problem with this settings.
Broken Dual WAN webui is a known issue in 374.43, it was broken in Asus's 374_5656 code. Should be fixed in their latest code, but I haven't tested it.
Ok, thx. Is there more useful mode to debug dual wan, syslog is no informative?
No. The firmware doesn't log much in relation to it (and the code isn't really documented either, making it hard to understand how it works).
