Oh my god...thats annoying since I didn't make a backup. I will check tomorrow.@zakazak - just to test I re-installed FlexQos via amtm menu item 3 and used same settings I had used moons ago before switching to Cake.
The Tools Tab page clearly showed for HW Acceleration that both Runner and Flow cache were enabled.
However - I got LOTS of these error message lines - suggesting that Flow Cache was buggy [to put it mildly] ..
The log file was being filled with these "Duplicate blog" lines.Code:kernel: [0;33;41mFCACHEfc_vblog_list_add ERROR: Duplicate blog: list blog<0xffffffc02f8b24c0> JOIN blog<0xffffffc02f8b1300>[0m
What is more curious is that even after uninstalling FlexQos and reverting to Cake - the above Flow Cache errors continued to show up - even after reboots and power off and power on.
The only way to get back to a clean install for me was to factory reset [and WPS button reset] - then load my Config Settings from saved backup before my games with FlexQos started - as well as reformat JFFS partition and restore my JFFS backup taken before FlexQos install.
Only after all that am I back to clean logs. You should perhaps check your logs for FCACHE Error entries?
If you get these running Cake - then there may be some carry over from the FlexQos install/uninstall
The solution is as above provided you made a Config settings and JFFS backup before you installed FlexQos the first time.
How exactly did you check the logs? Via ssh or webinterface?
