.34 Dual WAN not saving settings
MrLawliet
Hi Merlin,
I've updated to .34 for the AC66U and I have this setup:
Primary WAN: Static IP
Secondary WAN: LAN1, Automatic IP
The problem is the Secondary WAN is showing the Static IP option selected with blank values of the Primary WAN under Network Map when clicked on, but in WAN settings LAN is set correctly to Automatic IP.
Screenshot of Secondary WAN in Network Map: http://i.imgur.com/LNC4FYS.png
Since it says "Connected" for it I assume it is doing Automatic IP, but I can't test the fallback until later today.
If you can, let me know if this looks cosmetic or may be a bigger issue.
I'm not sure because I don't deal with the Dual WAN code, but I suspect that Connected merely indicates that the Ethernet cable is connected. If you are in failover mode, it won't obtain an IP until needed AFAIK.
I have DW on 34 and all seem to be OK but I have PPOE not static IP, from your screenshot it looks like is not connecting.
Check the second WAN setting, as is a fallback it my be possible that you have set a value different from 0 on
"Idle Disconnect Time in seconds: Disconnect after time of inactivity (in seconds)"
if so it will not connect until he needs.
I use the balance, it's not perfect ( some lag and disconnection ) but at list give me more speed ;)
