ASUS AX88U Pro Dual WAN doesn't work properly
nishadrox
My AX88U Pro's dual wan on failover doesn't switch properly to the second network.
First network is a Fiber connection - Automatic IP
First network is a 4G connection - Automatic IP
When the primary WAN is disconnected the secondary WAN just switches between Cold Standby, Hot Standby and the below shown DHCP error. But never says Connected.
But as a primary WAN the 4G connection works properly.
Any ideas what could be wrong here?
When the primary WAN is connected:
Multiple Dual WAN issues threads on SNB Forums. This feature is not very reliable on Asus routers. You basically have to find your own solution.
