Hi all,
I am trying to convince my router to function in Access Point mode but for some reason it is not forwarding the wifi/wired DHCP requests to the main router (a pfsense router). The pfsense hosted DHCP worked and works flawlessly but when I connect my macbook pro to the asus and wait for it to get an IP address from pfsense, it waits and waits and ends up with a "self-assigned" IP address.
The odd thing is, rt-n66u worked fine in Access Point mode up until I decided it's time for a reset due some slow wifi connectivity. Since then, I reset it to defaults multiple times, to no avail.
Any help is appreciated. Thank you.
Update 1: I forgot to mention that I tried both dynamic IP and static IP for the AP, with the correct values for IP, subnet, gateway. The moment I click apply button my mbp connection goes dark. Even if I try to use a manual IP on my laptop, I'm not able to reach the pfsense.
