Makaveli
This is a Alpha testing thread am i wrong ?? Bug reports will be posted here..![]()
Are those log entries affecting your usage and performance of the router?
I have one of the RT-AX58U units.Are those log entries affecting your usage and performance of the router?
@Kal-EL you're up.Anyone brave enough to test a completely untested RT-AX56U build? (don't have one to test it).
You're right. I should read better.That is a different router he has the RT-AX58U
Fire it up ! i have a RT-AX56U waiting !Anyone brave enough to test a completely untested RT-AX56U build? (don't have one to test it).
Thanks, I was able to get it tested by themiron.
Sorted out one last issue with it, so RT-AX56U support will be available in 384.16.
One odd thing that I noticed (a Linux thing) is that when I use command "top" via SSH to check the CPU load, the normal Linux load averages look wrong. The RT-AX58U load typically is less then 6% per core.
Using SSH and "top" command and press number "1" to see all the cores individually:
Mem: 215508K used, 296752K free, 1020K shrd, 0K buff, 16076K cached
CPU0: 0.3% usr 1.1% sys 0.0% nic 98.2% idle 0.0% io 0.0% irq 0.1% sirq
CPU1: 0.5% usr 3.7% sys 0.0% nic 94.6% idle 0.0% io 0.0% irq 0.9% sirq
CPU2: 0.0% usr 1.1% sys 0.0% nic 98.8% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 0.46 0.44 0.45 1/125 11189
If I look at all the cores averaged
CPU: 0.5% usr 2.1% sys 0.0% nic 97.0% idle 0.0% io 0.0% irq 0.2% sirq
The 1, 5, 15 minute load averages seem incorrect. The system is not running at 46% load and it is not running at .46% load either. Each core is running at around 6% or less all the time, and the average of all cores combined is less than 3%. So not sure what the 1, 5, 15 minute load averages are showing me.
Great news, I've also got an AX56U if you need anyone else to test.
56U Gpl just emerged.
"Version 3.0.0.4.384.82532020/03/06 1.76 GBytes
GPL of ASUS RT-AX56U for firmware 3.0.0.4.384.8253"
https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX56U/GPL_RT_AX56U_30043848253.zip
commit 91b0ba80f16edab98ac68caeba582a89740b76b6
Author: Eric Sauvageau <[email protected]>
Date: Tue Mar 3 17:01:23 2020 -0500
Merged with GPL 384_8253 (from RT-AX56U)
I use OpenVPN with no apperant issue. I only use it on my phone though and autoconnect with VPN Client Pro on wifi connections that is not on my whitelist. (AX88U)I'm having a problem when using the dhcp-option with my VPN client. When I use that option my wireless Laptop can't seem to automatically connect when booting up. When using an ethernet connection on my other Laptop I don't have this problem. When I revert back to 384.15 everything works as it should.
| Thread starter | Title | Forum | Replies | Date |
| S | 102.7 Alpha Builds available | Asuswrt-Merlin | 150 | |
[ 3004_388.11 alpha Build(s) ] available build(s) | Asuswrt-Merlin | 36 | |
[ 3006.102.6 alpha Build(s) ] available build(s) | Asuswrt-Merlin | 206 | |
[ 3006.102.5 alpha Build(s) ] available build(s) | Asuswrt-Merlin | 111 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
