[384.9_Alpha - builds] Testing all variants.
@RMerlin WOW! Nice work on the new QOS tab "Classification," formally know as "QOS Stats." The effects look awesome in Chromium for Ubuntu. This new alpha 2 is awesome!;):)
Okay so I tried the new alpha2*69b ... but it stills looses my wifi, back to alpha1*98d with no problem with wifi
What am I missing here? Do I need to factory reset after upgrading to Alpha2?
I see a lot of erros in the log
Been on alpha2 69b for 4 hours and everything is fine except for the dcd crashes. Great work Eric :)
Don't reset for an alpha version. Stay with what works until the release is final then flash and reset.;):)
alpha2 on my 3200 seems to be working well , what problems are others having with alph2 on the 3200 if any , i'll check mine more closely to see if i have te sameproblems
Hello,
I just installed the latest alpha v2 as i had no luck on the release or alpha v1, when it comes to deleting folders from the routers side.
I can't delete the main folders, from file manager on windows 10 either.
So i wonder if anyone got any solution to this.
What is your memory usage at - I have AI Network Protection on. Mine is running at ~180 MB. It seems a little higher than before alpha.
Linux uses memory different than a windows environment. I wouldn't be concerned. This topic has been tossed around here a lot, just do a search.
o Special binary blobs provided by Asus for the RT-AC87U
My sincere thanks to both for the cooperative efforts.
Use WinSCP. Enable ssh, log into the router, browse to /mnt/usbdrive and delete to your heart's content.
Sent from my SM-T380 using Tapatalk
installed RT-AX88U_384.9_alpha2-gb16bc2518 last night from 384.2 but 5g wireless not working, its enabled but in Sysinfo it shows its disabled. see attachments
Anyone have any ideas?
Minidnla on Alpha 2 for video files still not working, the list of file is not displayed. Music is working. Any clues?
Yeah, MiniDLNA can't add new movies to database in alpha2 builds. I chose to rebuild the database now I can't found any file. haha
Reverting to last stable build.
