ComputerSteve
Is there a way to erase OpenVPN without resetting the whole router config and putting it back to defaults.There's your problem.
Even after I go to Default on the bottom when I go back into the interface I see this Connecting... ( udp:1194) .. Meanwhile nothing is even configured.Is there a way to erase OpenVPN without resetting the whole router config and putting it back to defaults.
And nothing was changed in the OpenVPN code. The error message is pretty straightforward - your login is getting rejected by your provider. Check that your provider hasn't changed something with their login process (some providers switched from the main login to forcing their users to use a username/password pair that has to be generated through their portal), or that your subscription hasn't expired.Right but nothing changed. I also tried to re-set it up and each time it just says connecting. I then tried a different VPN VPN.Asia Same error.
This is an alpha build...make a backup of the stable build and you should reset after upgrading to the alpha.Right but nothing changed. I also tried to re-set it up and each time it just says connecting. I then tried a different VPN VPN.Asia Same error.
SO maybe it is something with the provider.. Switched to my backup VPN which is VPNSecure & it seems to be working.. Question what is the default settings for the System Log? Is it Info & Debug / Or Notice & Debug?And nothing was changed in the OpenVPN code. The error message is pretty straightforward - your login is getting rejected by your provider. Check that your provider hasn't changed something with their login process (some providers switched from the main login to forcing their users to use a username/password pair that has to be generated through their portal), or that your subscription hasn't expired.
My RT-AX-86U router has the same issue. I have 386.2_4 installed. I'm using NordVPN and NextDNS. Sometimes the router hangs out of being able to connect to NordVPN. I do not think it's an error when entering the credentials. After turning VPN access on and off several times, the router ends up logging in. I think there is something that interferes with the validation of the credentials, but I don't know what it is ... I have noticed that this usually happens after resetting the router. However, I can access to NordVPN from the android app or a PC with my credentials...And nothing was changed in the OpenVPN code. The error message is pretty straightforward - your login is getting rejected by your provider. Check that your provider hasn't changed something with their login process (some providers switched from the main login to forcing their users to use a username/password pair that has to be generated through their portal), or that your subscription hasn't expired.
Hello RMerlin. As the new GPL is to be waited for some time and the new wireless drivers solves a security issue, do you intend to release a new intermediate FW version (not alpha) after the necessary testing, or will you follow the typical development schedule?It's not a new GPL, it's just updated wireless drivers. GPL releases are currently on hold while some things get sorted out. (it's complicated).
I've noticed that also.My RT-AX-86U router has the same issue. I have 386.2_4 installed. I'm using NordVPN and NextDNS. Sometimes the router hangs out of being able to connect to NordVPN. I do not think it's an error when entering the credentials. After turning VPN access on and off several times, the router ends up logging in. I think there is something that interferes with the validation of the credentials, but I don't know what it is ... I have noticed that this usually happens after resetting the router. However, I can access to NordVPN from the android app or a PC with my credentials...
I plan on issuing a release to include the security fix. I haven't decided yet if it will also include the other changes that are currently in the 386.3 alpha, or if I will just backport the driver fix to 386.2_x and issue a point release. For now I'm waiting to get fixes for the two missing models.Hello RMerlin. As the new GPL is to be waited for some time and the new wireless drivers solves a security issue, do you intend to release a new intermediate FW version (not alpha) after the necessary testing, or will you follow the typical development schedule?
Failure to connect can occur for a number of reason. This other user had an error message stating that his username/password was rejected. Check your system log to determine if it's really the same problem, or something completely different.My RT-AX-86U router has the same issue. I have 386.2_4 installed.
Firmware upgrade unsuccessful. This may result from incorrect image or error transmission. Please check the version of firmware and try again.
	On my RT-AC86U's [now retired in favour of RT-AX86U's] - I never once succeeded with a firmware upgrade without issues if I failed to first eject USB and ensure that all USB dependent apps had closed successfully - judged by a big drop in consumed RAM. On occasion even ejecting the USB was not good enough - and had to disable JFFS scripts under Admin Tab then reboot without the USB - then flash firmware.Unable to install RT-AC86U_386.3_alpha1-gb5bff52d3d_cferom_ubi.w on my AC86U (currently running 386.3 alpha 1 #gedfbfacce8):
Code:Firmware upgrade unsuccessful. This may result from incorrect image or error transmission. Please check the version of firmware and try again.
The SHA-256 checksum seems OK though... (5e576ea838eda5c86245bea8bf895323a6980850d145e98b70668288c12480a4)
EDIT: I forgot to unmount the (Entware) USB drive... (This has happened before; but wasn't the error message different then?)
You need to follow Eric on twitter...I see a new folder on onedrive called "FragAttack". In this folder, it seems there are new alpha releases?
Can someone elaborate?
Edit:
Oh, found the explanation: https://www.snbforums.com/threads/beta-fragattack-patched-test-builds-386-2_5.72932/unread
Welcome To SNBForums
