Jan 29 18:04:17 hostapd: eth7: STA 3c:7c:3f:xx:xx:xx IEEE 802.11: associated
Jan 29 18:04:17 hostapd: eth7: STA 3c:7c:3f:xx:xx:xx RADIUS: starting accounting session 8B40A91994885392
Jan 29 18:04:17 hostapd: eth7: STA 3c:7c:3f:xx:xx:xx WPA: pairwise key handshake completed (RSN)
Jan 29 17:04:17 kernel: wfd_registerdevice Successfully registered dev wds1.0.1 ifidx 1 wfd_idx 1
Jan 29 17:04:17 kernel: Register interface [wds1.0.1] MAC: 24:4b:fe:xx:xx:xx
Jan 29 17:04:17 kernel: device wds1.0.1 entered promiscuous mode
Jan 29 17:04:17 kernel: br0: port 11(wds1.0.1) entered forwarding state
Mine has been doing this since 384 alpha1. When I reboot it always goes to GMT time on and off. Then I press the apply button and it goes back to EST.Just updated to 385 Alpha1 and working fine, though kernel time difference is still there.
Thanks, tested that and seems that synced time for kernel.Mine has been doing this since 384 alpha1. When I reboot it always goes to GMT time on and off. Then I press the apply button and it goes back to EST.
Still see same issues with original Nest cam indoor on AX56u on this alpha....i.e. Regular and repeated offline periods/disconnections.This has my interest.... will keep an eye out for an AX88U variant to try with my Nest/TP-Link/IOT devices.
That's not good news.Still see same issues with original Nest cam indoor on AX56u on this alpha....i.e. Regular and repeated offline periods/disconnections.
Still obviously a stock firmware issue vs. Merlin though. The AX56u is still on the 45 release for stock... and has the same issue. Was hoping the 46 release that other routers were receiving would resolve.....That's not good news.
OK - that's even more interesting then. I see the latest Asus stock for AX56U is 3.0.0.4.386.45934 from back in Nov. 2021 so that may explain why stock still sees an issue.Still obviously a stock firmware issue vs. Merlin though. The AX56u is still on the 45 release for stock... and has the same issue. Was hoping the 46 release that other routers were receiving would resolve.....
The ASUS 386_46065 stock firmwares for most AC models were just released last week (except for the RT-AC86U, which we are still waiting for). Stay tuned — @RMerlin will get to them when he receives the GPLs from ASUS and his schedule allows.He's working on or waiting on GPL for later-AC models? (or are they DQ'd?)
Are you using DOT for IOT devices?will keep an eye out for an AX88U variant to try with my Nest/TP-Link/IOT devices.
No but I route my DNS through my Pi-holes before it heads upstream to OpenDNS.Are you using DOT for IOT devices?
Welcome To SNBForums
