388.1 Rt-AX58U unable to flash back to stock
busch09
Hi, updated my RT-AX58U to Merlin 388.1. Now trying to revert to stock FW_RT_AX58U_300438822237.w, also tried FW_RT_AX3000_300438822525.w. GUI Firmware write fails, with "firmware upgrade unsuccessful"
Tried rescue mode upgrade. That fails too with Router not in recuse mode.
SSH command line upgrade fails with:
admin@RT-AX58U-ED08:/tmp/mnt/sda# bcm_flasher FW_RT_AX58U_300438822237.w
File size 0x602d430 (100848688)
imgif: Enabling NAND incremental flashing functions!
Flash type 0x2, flash size 0x5f00000, block size 0x20000
ERROR[validateWfiTag.1818]: The image type does not match the OTP configuration of the SoC. Aborting.
..................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................ERROR[imgif_nand_close.536]: Unexpected WFI tag content
ERROR!!! Did not successfully write image to NAND
admin@RT-AX58U-ED08:/tmp/mnt/sda# Connection to 192.168.50.1 closed by remote host.
Connection to 192.168.50.1 closed.
Any suggestions how to get back to stock?
Going back to Asus stock on the AX58U/3000, you must flash 386.45898 first. Then you can upgrade to the latest 388.22525.
Was able to revert to FW_RT_AX3000_300438822525.w using recovery mode.
You have to put the router into recovery mode. The trick is pulling the power plug and while holding the reset button with a toothpick and plugging the power back in the light will blink slowly when in recovery mode.
