[ 388.2 alpha Build(s) ] Testing available build(s)
Let's GO!
yay lets go
will report soon about how it performs
installed without a hitch
Jump to Alpha 2 from Alpha 1 on my APs all good so far. All devices re-connected and happy. Main router still on release version for now.
All my AX58U Main & Mesh units working okay on new A2.
@RMerlin Does this bring the GT-AX11000 on the master branch finally? GT-AX11000_388.2_alpha2-g099892a1cf
AIMesh webui looks a bit buggy with nothing displaying until you click on a node or router.
Everything compiled so far is from the master branch.
Both are alpha 2 (unless their is another revision yet to be released for the node)
That doesn’t mean they are based on the same GPL. The AX-11000 had been behind as well as the AX88U in that regard on the last releases.
This will happen if your node is on a newer build than your main.
I will say that now my GT-AX11000 with this new 22525 GPL takes almost exactly 10 secs to display any AiMesh info every time I click on the AiMesh page(my node has been on 22525 for a few weeks now). I've never had display delays even though the node is on a newer GPL until I updated the AX11000 to 22525
True that’s why I asked Merlin if the AX-11000 is now based on the master branch which should be the newest gpl. But I could be mistaken.
Mine will too but if I upgrade the AX86U that is a Node to the latest GPL available for it, it will break only on the status page but effectively it still works.
True that’s why I asked Merlin if the AX-11000 is now based on the master branch which should be the newest codebase. But I could be mistaken.
Possibly, I haven’t had a chance to look yet.
Damn I like the new site survey tool. I mean wifi radar never really worked well it never would show one of the 5-1ghz radios that deal with 160Mhz. Backhaul or the second 5Ghz radio 5-2 would show data.
