[ 388.2 alpha Build(s) ] Testing available build(s)
I had problems with the last release.
It turned out that all the certificates has been regenerated again.
Put the old ones in and it connected again.
Will check later if I can solve it like you did.
But it is weird that the router do not even display/register a connection attempt.
I did. Also tried to reconfigure OpenVPN from default. Didn't solve connection issue.
Seems your problem is on client side. Your server seems running.
Server seems running. Now I've tried with 2 other clients, Apple MBA and Lenovo Windows11 laptop. No connection.
Look at your client's log, it will tell you what's failing.
Clients on my wifi-network does connect but there is "no connection/data transfer". Clients on other networks doesn't connect at all.
Log from windows11 laptop.
[Feb 26, 2023, 18:21:30] OpenVPN core 3.git::d3f8b18b win x86_64 64-bit built on Feb  7 2023 16:08:10
[Feb 26, 2023, 18:21:30] Frame=512/2048/512 mssfix-ctrl=1250
[Feb 26, 2023, 18:21:30] UNUSED OPTIONS
4 [resolv-retry] [infinite]
5 [nobind]
7 [ncp-ciphers] [AES-256-GCM:AES-128-GCM:AES-256-CBC:AES-128-CBC:CHACHA20-POLY130...]
[Feb 26, 2023, 18:21:30] EVENT: RESOLVE [Feb 26, 2023, 18:21:30] Contacting 193.zz.yy.xx:1194 via UDP
[Feb 26, 2023, 18:21:30] EVENT: WAIT [Feb 26, 2023, 18:21:30] WinCommandAgent: transmitting bypass route to 193.zz.yy.xx
    "host" : "193.zz.yy.xx",
    "ipv6" : false
[Feb 26, 2023, 18:21:30] Connecting to [server_name.asuscomm.com]:1194 (193.zz.yy.xx) via UDPv4
[Feb 26, 2023, 18:21:30] EVENT: CONNECTING [Feb 26, 2023, 18:21:30] Tunnel Options:V4,dev-type tun,link-mtu 1541,tun-mtu 1500,proto UDPv4,cipher BF-CBC,auth SHA1,keysize 128,key-method 2,tls-client
[Feb 26, 2023, 18:21:30] Creds: Username/Password
[Feb 26, 2023, 18:21:30] Peer Info:
IV_VER=3.git::d3f8b18b
IV_PLAT=win
IV_NCP=2
IV_TCPNL=1
IV_PROTO=30
IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305:BF-CBC
IV_GUI_VER=OCWindows_3.3.7-2979
IV_SSO=webauth,openurl,crtext
IV_BS64DL=1
[Feb 26, 2023, 18:21:30] SSL Handshake: peer certificate: CN=RT-AX88U, 2048 bit RSA, cipher: TLS_AES_256_GCM_SHA384  TLSv1.3 Kx=any      Au=any  Enc=AESGCM(256) Mac=AEAD
[Feb 26, 2023, 18:21:30] Session is ACTIVE
[Feb 26, 2023, 18:21:30] EVENT: GET_CONFIG [Feb 26, 2023, 18:21:30] Sending PUSH_REQUEST to server...
[Feb 26, 2023, 18:21:30] OPTIONS:
0 [redirect-gateway] [def1]
1 [route-gateway] [10.8.0.1]
2 [topology] [subnet]
3 [ping] [15]
4 [ping-restart] [60]
5 [ifconfig] [10.8.0.2] [255.255.255.0]
6 [peer-id] [0]
7 [cipher] [AES-256-GCM]
8 [key-derivation] [tls-ekm]
[Feb 26, 2023, 18:21:30] PROTOCOL OPTIONS:
  cipher: AES-256-GCM
  digest: NONE
  key-derivation: TLS Keying Material Exporter [RFC5705]
  compress: NONE
  peer ID: 0
[Feb 26, 2023, 18:21:30] EVENT: ASSIGN_IP [Feb 26, 2023, 18:21:30] CAPTURED OPTIONS:
Session Name: server_name.asuscomm.com
Layer: OSI_LAYER_3
Remote Address: 193.zz.yy.xx
Tunnel Addresses:
  10.8.0.2/24 -> 10.8.0.1
Reroute Gateway: IPv4=1 IPv6=0 flags=[ ENABLE REROUTE_GW DEF1 IPv4 ]
Block IPv6: no
Add Routes:
Exclude Routes:
DNS Servers:
Search Domains:
[Feb 26, 2023, 18:21:31] SetupClient: transmitting tun setup list to \\.\pipe\agent_ovpnconnect
    "allow_local_dns_resolvers" : false,
    "confirm_event" : "1414000000000000",
    "destroy_event" : "6010000000000000",
    "tun" :
        "adapter_domain_suffix" : "",
        "block_ipv6" : false,
        "layer" : 3,
        "mtu" : 0,
        "remote_address" :
            "address" : "193.zz.yy.xx",
            "ipv6" : false
        "reroute_gw" :
            "flags" : 275,
            "ipv4" : true,
            "ipv6" : false
        "route_metric_default" : -1,
        "session_name" : "server_name.asuscomm.com",
        "tunnel_address_index_ipv4" : 0,
        "tunnel_address_index_ipv6" : -1,
        "tunnel_addresses" :
                "address" : "10.8.0.2",
                "gateway" : "10.8.0.1",
                "ipv6" : false,
                "metric" : -1,
                "net30" : false,
                "prefix_length" : 24
    "wintun" : false
POST np://[\\.\pipe\agent_ovpnconnect]/tun-setup : 200 OK
TAP ADAPTERS:
guid='{4854EF9B-61E1-44D6-A978-ED10E2062AF4}' index=51 name='Local Area Connection'
Open TAP device "Local Area Connection" PATH="\\.\Global\{4854EF9B-61E1-44D6-A978-ED10E2062AF4}.tap" SUCCEEDED
TAP-Windows Driver Version 9.24
ActionDeleteAllRoutesOnInterface iface_index=51
netsh interface ip set interface 51 metric=1
Ok.
netsh interface ip set address 51 static 10.8.0.2 255.255.255.0 gateway=10.8.0.1 store=active
netsh interface ip add route 193.zz.yy.xx/32 9 192.168.50.1 store=active
The object already exists.
netsh interface ip add route 0.0.0.0/1 51 10.8.0.1 store=active
Ok.
netsh interface ip add route 128.0.0.0/1 51 10.8.0.1 store=active
Ok.
ipconfig /flushdns
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
TAP: ARP flush succeeded
TAP handle: 6c09000000000000
[Feb 26, 2023, 18:21:31] Connected via TUN_WIN
[Feb 26, 2023, 18:21:31] EVENT: CONNECTED client_10@server_name.asuscomm.com:1194 (193.zz.yy.xx) via /UDPv4 on TUN_WIN/10.8.0.2/ gw=[10.8.0.1/][Feb 26, 2023, 18:23:43] SetupClient: signaling tun destroy event
[Feb 26, 2023, 18:23:43] EVENT: DISCONNECTED
5 [nobind]
    "ipv6" : false
IV_PLAT=win
IV_NCP=2
IV_TCPNL=1
IV_PROTO=30
IV_BS64DL=1
3 [ping] [15]
6 [peer-id] [0]
  cipher: AES-256-GCM
  digest: NONE
  compress: NONE
  peer ID: 0
Layer: OSI_LAYER_3
Tunnel Addresses:
Block IPv6: no
Add Routes:
Exclude Routes:
DNS Servers:
Search Domains:
    "tun" :
        "layer" : 3,
        "mtu" : 0,
        "remote_address" :
            "ipv6" : false
        "reroute_gw" :
            "flags" : 275,
            "ipv4" : true,
            "ipv6" : false
                "ipv6" : false,
                "metric" : -1,
                "net30" : false,
    "wintun" : false
TAP ADAPTERS:
Ok.
Ok.
Ok.
ipconfig /flushdns
If I remember right is cipher BF-CBC deprecated
I'm using the default Data ciphers in OpenVPN server setup:
AES-256-GCM:AES-128-GCM:AES-256-CBC:AES-128-CBC:CHACHA20-POLY1305
No BF-CBC ...
No BF-CBC ...
OK I can see it now you use cipher AES-256-GCM
SENT CONTROL [client]: 'PUSH_REPLY,redirect-gateway def1,route-gateway 10.8.0.1,topology subnet,ping 15,ping-restart 60,ifconfig 10.8.0.2 255.255.255.0,peer-id 0,cipher AES-256-GCM,key-derivation tls-ekm' (status=1)
Checked the server cert and key and it had indeed changed after update to alpha2
I restored the old cert and key and restarted the vpn server, But still no go here..
As written before i do not even see a connection attempt in the router
Any ideas?
edit:
Tested another Android openvpn client now also (OpenVPN Connect)
Same thing and i get no clues for errors in that log either and nothing in router syslog or vpn status page.
@RMerlin
this is a problem with the permission in firewall table. if disabled firewall open vpn work
@RMerlin
Tested to disable firewall and now i see connection attempts in syslog but get:
Feb 26 20:55:12 RT-AX88U ovpn-server1[264035]: read UDPv4 [CMSG=8|ECONNREFUSED]: Connection refused (fd=9,code=111)
Disabled the firewall and clients now connect as normal. Re-eanbled firewall and clients don't connect. Definitely looks like a firewall issue.
I did redownload the config files before I tried this and re-setup the clients.
AX88U *2 and AX56U, smoorh upgrade from 388.1 to 388.2 alpha 2.
Ran it for 5 minutes and rebooted the whole system.
Seems new WiFi drivers have imoroved a bit the signal for 5Ghz.
So far, so good.
Did not see the release was on Saturday, was out protesting
Glad I entered today here ;)
Thank you
@RMerlin
With firewall disabled, clients on other networks connects, but still no datatransfer.
"Advertise DNS to clients" enabled/disabled didn't make a difference.
Reverted to 388.1 for now.
Open VPN servers working again.
Firewall configuration is currently broken when setting up an OVPN server (proto is truncated when checking for udp or tcp).
