5.4Ghz Band - channel 0?
lindros2
Never seen this before...
My 5.4Ghz-2 channel is showing "auto", but to the right it says "Channel 0"
... and when I go to select it, the drop-down is empty/null.
It always helps to know the router and firmware being used, at a minimum. :)
Does powering down the router and leaving it 'on', but physically unplugging the power plug from the router itself, for 2 minutes before powering it back up, help?
AC5300. Merlin 386 b2.
Reboot helped. But it reboots every Sunday so it was pretty fresh today.
Often changing/forcing 5G channel (i.e. 149 > 153) fixes things (ie AC68U which have disconnected). Not this time.
Finally, clients were connected. It was maybe a UI thing, but - since my extender dropped off - I wanted to change channel before reboot or unplug.
I'd be testing with RMerlin 386.1 Beta 4 today. :)
